- First Name
- Neil
- Joined
- Aug 11, 2020
- Threads
- 0
- Messages
- 59
- Reaction score
- 113
- Location
- Massachusetts
- Vehicle(s)
- 2017 Audi A4
- Your Bronco Model
- Black Diamond
Did you have any issues with the rear rail on the roof rack? I have a 2 door and installed the side rails (pretty simple), but the rear cross rail does not line up correctly. I know I have the crossbar in the correct position, because of the contour of the rail, and the screws line up with the holes. But when I get one side screwed in, the screws on the other side just fall short of lining up. I loosened the side rails so I could get all 4 screws in, but then it pulls the side rails in toward the center, and the clamping part of the rear rails are short of reaching the edge of the roof. I took the entire rack off, assembled it on the ground, then put it on the roof and I have the same issue, the 2 rear clamping feet on the side rails do not line up. One will go on and the other falls just short and does not make the edge of the roof.Nope, it's super easy.
Hell we swapped both roofs and had the roof rack mounted within an hour.
I have watched a couple of videos of the install, and it looks pretty simple. It looks like the rear rail goes on easy. I called the dealer and they were no help. I scheduled an appointment so they could take a look at it. I wonder if my rear rail may have a bigger bend in it that is causing my issue.
