Why is the new Bronco Raptor so heavy and fat??
06viper
Albuquerque, NM
2020 Raptor, 2021 Mclaren 765LT, 1965 Shelby Cobra
I get it, Ford added 37's, beefed up the frame and suspension, threw on some larger fenders, and put in a slightly larger V6 which will all add weight. But how on earth does that add on an extra 1000lbs over a regular 4 door Bronco?? My loaded 2020 F150 Raptor Supercrew weights 5,500lbs which is 200lbs lighter than a Bronco Raptor! I get that these things aren't build for lightness in mind, but an extra 1000lbs over a regular 4 door Bronco is HEAVY! That 1000lbs will be quite noticeable in just about every aspect of driving both on and offroad. What do you guys think also added major weight onto this thing to make it so dang heavy over a regular Bronco?
Lewisj41
Jesse
Maryland
2017 Tacoma
It's the big booty.
T Copp
Travis
KC
Bronco, Mercedes GLB
Give me half of your car collection and Iā€™ll tell ya.
vrtical
Doug
GSMNP, TN
Fords
the majority IS unsprung weight in the driveline. you forgot the D50 housings along with larger spline half shafts, there is a long list on the Braptor where everything is heavier. it doesnt take much to start adding up parts to get to 1000 lbs.
SavSqch
Savas
CT
2022 Wildtrak
Cause it gobbled up so many Creeper Jeeperā€™s!!!!
Plus a little heft never hurt anyone!!
Raptor has a fat ass and itā€™s juicy and glorious!!!!
CVSJR
Chuck
NJ
'66 Bronco, '09 Z06
Loaded 4 door "regular Bronco" weighs as much as 5320lbs, that's a 500lb difference. Bigger axles, steering gear, suspension parts, bracing on the frame and roof pillars and even better seats all contribute to the weight.
Spooled
Republic of Texas
It's really only about 500lbs heavier than a Squatch BL. Everything adds up. It is heavy though, I agree.
06viper
06viper
Albuquerque, NM
Car and Driver is saying it's 793lbs more than a 4 door Sasquatch and Motortrend is saying 1000lbs...
https://www.caranddriver.com/reviews/a40326408/2022-ford-bronco-raptor-drive/
https://www.motortrend.com/reviews/2022-ford-bronco-raptor-first-test-0-60-mph-review/
GToddC5
Todd
South Jersey
www.bronco6g.com
Spooled
Republic of Texas
A BaseSquatch is probably what C&D is comparing it too. A loaded BL/FE is 5320
Ford Bronco Why is the new Bronco Raptor so heavy and fat?? 2021 Bronco Curb Weight Dimensions
JohnGalt
Tahoe, CA
2023 Defender 110
The list is seemingly endlessā€¦
37s x 5
Rear Gate reinforcement for 37 spare
F150 axles, brakes and suspension
Frame strengthening
B bar and C reinforcementā€™
Additional Skid protection
Additional cooling
All 4 quarter panels are larger, but not sure if theyā€™re heavier or not
Probably heavier hood
Hood hinge pistons
Flares and liners
Additional cooling
Probably seats are heavier
Paddle shifters migh be lighter
I believe floor mats are standard on all Raptors which could be contributing more weight vs. ā€œstandardā€ bronco
It appears modular bumper ends are longer
Raptor lighting in bumper
Additional engine components and ducting
ā€œTrueā€ Dual exhaust is likely heavier
Tail lights ā€˜ proximity sensor appear larger
Air dam bits in front of front wheels
Probably numerous reinforcements and heavier hardware
Probably moreā€¦.
Not surprising itā€™s added 1000 pounds. Not super excited about extra weight, but what you get in return (except straight line speed and low MPG) seems totally worth it.
That said my old Lotus Elise weighed a third of Bronco Raptor. I do appreciate lightness!
Broncotrax
NORCO
69 Bronco, '17 Superduity, '22 Badsquatch, CR 250R
Because it's only offered in the crew cab model??? šŸ¤·ā€ā™‚ļø
