But I want both!Because the Wildtrak is supposed to be like the “desert runner” package.
I am only light trail and only light sand use. I want the very best bronco money can buy. Which should I get then?Because the Wildtrak is supposed to be like the “desert runner” package.
If you only lightly trail you probably won’t encounter any situations where the sway bar disconnect will be useful to you anyways so why worry about it? Stick with the Wildtrak.I am only light trail and only light sand use. I want the very best bronco money can buy. Which should I get then?
Thank you. Back in the day I built series 2a chasis with disconnects but that was on solid axles and I knew the suspension modifications I had made. I will admit I've gotten older and enjoy the harder trails less and less.If you only lightly trail you probably won’t encounter any situations where the sway bar disconnect will be useful to you anyways so why worry about it? Stick with the Wildtrak.
People tend to want all the tech, and options possible even if they won’t use it... it’s always the “if”If you only lightly trail you probably won’t encounter any situations where the sway bar disconnect will be useful to you anyways so why worry about it? Stick with the Wildtrak.
WT & FE comes with Sasquatch as standard.People tend to want all the tech, and options possible even if they won’t use it... it’s always the “if”
Besides this is all speculation until we see the builder
Anyone seen the graphics that are touted for the WT and FE? From what I’m seeing the only difference at the top BL, WT, and FE are carpet/rubber and the sway bar (leather etc is optional) And the graphics
No Sport mode on the Badlands that's why it's not the model for me, boooo fordBadlands optioned out should be well over $60k and have everything available. Go with that....no need to start 2 threads on the same topic though
