Decent lifts for Rangers look like they are $1000 or less and it doesn’t take brain surgery to put it on yourself. You would have to have an alignment done. I think you can do better than $2500 on wheels and tires if you shopped around. Even so, $3500 is way cheaper if you just want the look and don’t need the beadlock rims or front locker.Very basic aftermarket wheels like a Method with BFG KO2's will run you $2500 from Tirerack. Lift and labor?
Pretty sure somebody discussed it before. Almost sure of it. Would have to use the search function to verify so lets just assume nobody did that and make a thread about it.A topic literally nobody has ever discussed before... ever...
The badlands for instance uses different shocks than the base so pretty sure sasquatch has different shocks from base.Yeah this is not true.
The OP asked for differences between a Sasquatch and Base Badlands. Both get the Bilsteins.The badlands for instance uses different shocks than the base so pretty sure sasquatch has different shocks from base.
Guessing, without delving into thread after thread, that some people speculate they are different. Some believe they are the same. The only difference being in the limitation of travel.The shocks are different and I would guess the spring rates as well.
Nope. Not sure how this topic could have bounced down the road without us beating that horse to water.A topic literally nobody has ever discussed before... ever...
@Squatch @broncosorPretty sure somebody discussed it before. Almost sure of it. Would have to use the search function to verify so lets just assume nobody did that and make a thread about it.
You can get the 4.70 gears with the automatic, no Sasquatch .So the only difference between a Badlands and a Sasquatch Badlands is 4.7 vs 4.46, a small lift and of course the 35 tires and fenders.
We already know we can order the fenders as an accessory and of course 35 tires.
I would gladly order Sasquatch from the factory, but I need a roof rack and it seems the roof rack cannot be ordered as an accessory from the dealer. So I am stuck getting a base Badlands. Will it be easy for me to add 35 tires and will the 4.46 be an issue?
You would also need the wheels to fit the 35s. They're wider than the 33s.So the only difference between a Badlands and a Sasquatch Badlands is 4.7 vs 4.46, a small lift and of course the 35 tires and fenders.
not according to the order guide you can't. I know the B&P allowed it but order guide states otherwise.You can get the 4.70 gears with the automatic, no Sasquatch .
