Will sasquatch wheels and tires fit on a stock bronco no lift?
Richw23
Richw23
Rich
Massachusetts
2021 Ford Bronco Base/Sasquatch
For me, this would be just for the drive home from the dealer. About 3 hrs away. The lift would happen as soon as I got home.
not the question, but i agree. I was asking for my wife’s big bend she has on order. I was gonna sell my sas wheels and tires but then she ordered a 2 door and i said u can have my wheels and tires. Just wanted to make sure they would fir by others experience. I have 37’s and 1 inch level on mine for now. No rub. She wants a mall crawler
JohnnyBronco
Pennsylania
X4
Only caveat to what's already added is that she avoid deep, vehicle eating potholes at speed since there could be possibility of rub against fender extensions at full suspension compression. I had that issue on a '74 Hi-Lux (early Toyota pickup for the younguns here) but since they were just metal fenders without extensions I was able to "expand" them a bit with a 5# hammer. Worst case you replace the fender extensions with aftermarket.
TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2023 GMC AT4 HDD
I swapped steeliest on my Black Diamond and put on Sasquatch wheels with tires. Just had to remove crash bars. No issue with offset so far. Haven’t gone off-roading, but all seems to be fine.
I like that color match keypad. Do tell.
adrencg
Bronco Badlands Sport
Not to hijack this thread, but would crash bars need to be removed for 33.8 inch tires?
Richw23
Richw23
Rich
Massachusetts
i would imagine so. the sasquatch tires are not much more than 34" having measured them when they were on my Bronco, i think they came in at 33 14/16". so less than 34' and that was on the mounted tires front and rear. the back spare was harder to truly measure on the vehicle but with no weight on it, was slightly larger from how i measured coming in at 34 1/4"
Sail
Texas/Maine
Many
I really liked the black steel rim look
MJBbase22
M
Alfa Romeo Sider, VW GTI
Sweet top. Details/link?
alabamadave
Tuscaloosa, AL
1996 Chevy Silverado
Yes, they will fit, no issues, just remove the crash bars.
Here's my NO LIFT Base base. 35 x 11.5 ... +35mm offset. No poke. Standard flares.
How is your mpg with 11.5 wide toyo tire and new wheels?
listoparanada
Brady
Kia Soul
Have you taken it off-roading since? Any rubbing or issues with tire clearance? Doing a similar setup
adrewpower
Drew
F150 & Bronco
I put the RPG perch collars on to add a little lift. So I never tested off-roading without a lift. But mall curb-stops were no challenge for this built wild beast. 🤣
But seriously, I never had issues on light off-roading trails.
BWepps
Huntley, IL USA
2022 Ford Bronco Outer Banks
my wife ordered a big bend 2 door and has zero aspirations to ever go offroad. Will she be able to fit my sasquatch wheels and tires with no lift? This will literally be a mall crawler in the truest sense. Please help those that have tried. Thanks everybody. For the record this pic is strictly for attention, but happens to be almost exact to my wifes build. Thanks again
Per the other replies, just remove the front crash bars or they will rub on tight turns. I did the swap to Wildtrak (SAS) take-off wheels and tires last week onto my OBX. Fit no problem without a lift.
Ford Bronco Will sasquatch wheels and tires fit on a stock bronco no lift? Image-1
wongjitsu
Kingking1!
@BWepps how much poke do you have? Switching my stock big bend wheels and tires with SAS wheels and tires like yours.
