Will sasquatch wheels and tires fit on a stock bronco no lift?
Richw23
Rich
Massachusetts
2021 Ford Bronco Base/Sasquatch
my wife ordered a big bend 2 door and has zero aspirations to ever go offroad. Will she be able to fit my sasquatch wheels and tires with no lift? This will literally be a mall crawler in the truest sense. Please help those that have tried. Thanks everybody. For the record this pic is strictly for attention, but happens to be almost exact to my wifes build. Thanks again
StachioAttack72
Paul
Connecticut
Bronco 4 Door Outer Banks
Just remove the front crash bars and replace them if you want with the 4WP aftermarket low profile ones and the 315/79/17’s fit just fine. See my OBX below, I put on a 1” Rough County Leveling Kit in the front just for a stance but it wasn’t necessary.
Ford Bronco Will sasquatch wheels and tires fit on a stock bronco no lift? 8D4BA040-CFF9-4C46-BC80-17C8CF22151A
Richw23
Richw23
Rich
Massachusetts
I am more concerned with the offset and if it will be enough. Offset is +30 on sasquatch, what is urs at? Thanks
adrewpower
Drew
F150 & Bronco
I swapped steeliest on my Black Diamond and put on Sasquatch wheels with tires. Just had to remove crash bars. No issue with offset so far. Haven’t gone off-roading, but all seems to be fine.
Richw23
Richw23
Rich
Massachusetts
Great to hear. If u have any pics i would appreciate it. Thanks again
edgeflyer
2013 FX4
How much rub with the crashbars? Would it be ok to drive on the street for a few days?
StachioAttack72
Paul
Connecticut
Lots of rub if you leave the crashbars in, not worth it UNLESS you buy and install the aftermarket ones from 4WP or just remove them completely.
adrewpower
Drew
F150 & Bronco
Some crash bar rubbing with the Ford Sasquatch wheels. Mostly when close to full turn. I was going to leave it but decided against it. Figured it wasn’t a big deal if everyone was running legit Sasquatch set-up without crash bars. So I took them off. Hindsight, should have gone Sas with my build like I originally planned. If you can make the change at this point, it’s highly recommended. You never know when the wife will want to go from mall crawlin’ to rock crawlin’. Good luck.
HoosierDaddy
Yes, they will fit, no issues, just remove the crash bars.
Here's my NO LIFT Base base. 35 x 11.5 ... +35mm offset. No poke. Standard flares.
Ford Bronco Will sasquatch wheels and tires fit on a stock bronco no lift? 1648522340057
Ford Bronco Will sasquatch wheels and tires fit on a stock bronco no lift? 1648522404517
1975U15
2019 F-350 SD, 1975 Bronco
Such a great set up here. Supaflush for those that want it. Give me tint and she dialed.
Richw23
Richw23
Rich
Massachusetts
Thats why i have my sas bronco with 37’s
edgeflyer
2013 FX4
For me, this would be just for the drive home from the dealer. About 3 hrs away. The lift would happen as soon as I got home.
