I can see some with the winch control box relocated. I canāt see downward like for rock crawling. I havenāt decided fully what I want to do.How about front camera?
Aside from the front camera interference, this solution looks like it would fit with my JCR prerunner bar. Iād like to find/make something similar out of aluminum that is a bit lower profile to the bumper to block the camera less.I can see some with the winch control box relocated. I canāt see downward like for rock crawling. I havenāt decided fully what I want to do.
More pics here.Do you have a side view picture?
I'd like to see how far out it sticks.
Thanks
Full post with photos and tape measures to show exact distance on my original post.Do you have a side view picture?
Thanks
Almost sideways on wifeās Bronco. I did the same setup.Do you have a side view picture?
Thanks
Weight is a concern for me too, but with different setup. I added a Westin XTS bumper with winch and not sure total weight gain, but probably 140# over stock plastic bumper. I lost almost 1-1/2ā of height on the front and steering felt much heavier and had more brake dive. For now the winch is back off and trying to scheme how to correct the sag without replacing shocks. SAS Bilsteins, S code spring. Looking for input.I really donāt want to add 120# (49# for the mount and 70# for the winch) on the front bumper, but this setup does look really good compared to most options.
Just going to a V6 spring should get you most of the way there. V6 Sasquatch is probably just about perfect.Weight is a concern for me too, but with different setup. I added a Westin XTS bumper with winch and not sure total weight gain, but probably 140# over stock plastic bumper. I lost almost 1-1/2ā of height on the front and steering felt much heavier and had more brake dive. For now the winch is back off and trying to scheme how to correct the sag without replacing shocks. SAS Bilsteins, S code spring. Looking for input.
