Will the slide out tailgate delete the storage cubby underneath it?
TiredOldMedic
Hanson, Ky
99 Mercury Grand Marquis, 86 Dodge Ram
Advertisement
Jr87mustang
Josh
Northern Cali
This is something we asked quite a while ago and never got any answer.I would think that it doesn't allow you to get under it, but then again maybe that is why it was pushed so far back in the year.
ZackDanger
Zack
Massachusetts
2014 Wrangler JKU
No. That's where the jack goes.
What we don't know is how the slide out table is anchored to the floor.
It's possible that it's only anchored in the rear... the tray only slides out about a foot, which is only 1/3-1/2 the total depth of the cargo area/tray frame. I suspect this is so it can be robust enough to support a grown-ass-adult. Additionally, anchoring it at the front (rear of the vehicle... this is getting confusing) would be unnecessary.
It's conceivable that the entire table unit could remain anchored in the rear of it and swing up to allow access to the cubby... or maybe you have to unbolt / unlatch the table or something every time you want to access that space.
We just don't know yet.
Badsquatch2021
Chicago
Tbd
Last I heard it was bolted in. It's weight/load bearing so it has to be bolted in. I would think this loses the storage cubby and the cargo your downs. And it's already been started you can't fit the doors with it. I wanted it at first but I'll wait for a better solution.
TiredOldMedic
TiredOldMedic
Hanson, Ky
I want to set mine up like the Overlanding rig. I've been looking at small fridges and just trying to figure out how its all gonna work. Not sure if the fridge on a slide out tray would work with the tailgate.
Aman
Aman
Northern NJ
1998 BMW M3 (Track Car) & 2008 Nissan Armada
Good question. It almost needs to hinge in the front and latch down in the back to allow access
This is definitely the way it should be designed, but I doubt it is.
Headsong
08 Tundra
I believe I'd read that there were pop-out D rings. Gotta have easy access.
Jpeyer
Joshua
Ohio
2017 F250 Lariat
To be robust enough I doubt it is accessible. My bet would be on a flip up storage cubby on the seat side (front) of the tray. If they leave a void there you would have room for the jack and tooling.
Headsong
08 Tundra
I doubt it. Think about it, are they going to make different bodies? Just for the so-far non-existent slider? Which is an aftermarket accessory? It'll be removable.
Trueblue2296
Adam
Tennessee
Ranger, Explorer
It wont delete the storage just cover it and make it very difficult to get to. It’s a dealer installed accessory.
Jpeyer
Joshua
Ohio
2017 F250 Lariat
Of course it’s removable . It’ll probably be bolted in the corners where the d rings are that get removed to install this. I’m sure they will just come with longer bolts that go through a hole in the d ring. All I was saying is that they will make a permanent cubby to put the jack and tooling into. That cubby will be part of the tray assembly. No one is going to remove it once installed.
rmc523
South Florida
2009 Ford Flex; 2018 Mustang GT
Vehicle Showcase
I believe we figured out the doors WILL fit (remember the reveal cactus gray one had them in the back), but that the cargo area part of the apparatus covers the tether points that the doors attach to, so therefore Ford has to say you can't put them back there.
The Pope
If FoMoCo would have just given us a true drop down tailgate instead of coping Jeep's swinging tailgate, this would be a non-issue...... just saying
Advertisement
4x4TruckLEDs.com
Advertisement
