Wind noise before/after vid
RowsKing
JR
SJ
22 BRaptor, 66 Stang
Nothing much to look at, but I cut N pasted 2 videos before and after wind noise mods. This weekend I did most of the mods that have been posted about before. Videos taken at 60mph with phone held up to the rear view mirror. I’d say 50% reduction in wind noise, what do you think?
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
It does make a big difference.
FleshTuxedo
A
PA
'22 OBX 2dr.
How did you guys put the pipe insulators in the roof without taking the top off? I saw people said they just slid them in, but there was no way mine would even make it under the roof.
dadjoke
Southern California
'22 Bronco Big Bend 4-Door 2.7 MIC Auto Sasquatch
You would slide them in on top of the frame rails from the cargo area. I only know this since when I was putting my foam in, it came out there :ROFLMAO:
FleshTuxedo
A
PA
'22 OBX 2dr.
Hmm, perhaps I'll try that.
Ksjrb03
Tx
F250
There are so many hacks for this maybe list the ones you’ve done.
RowsKing
RowsKing
JR
SJ
For this before/after video, I did pipe insulation along the side rails. 1 inch square foam insulation along the channel on the windshield. On the roof panels themselves I put 1/4 rubber with adhesive along the fronts and backs and where the fronts overlap.
RowsKing
RowsKing
JR
SJ
I could have been clearer. I only put 1/4 inch rubber insulation on the front panels. I did not touch the mid panel or rear shell.
BBSas
Alabama
Can you redirect to the post you referenced? I remember seeing but can’t seem to find.
jharrell3623
NC OBX
2022 Bronco 4 Door Outer Banks 2.7L Hardtop
Buy a signal meter to measure decibels, its cheap and will let you know if there is a difference or not in an actual number. Phone app might exist as well. Just make as many variables the same , before and after. Like road surface , speed , wind speed and direction ( stationary ) in relation to travel at time of recording , etc. That way its accurate to know if what you done really made a huge difference. Oh and location of mic in cabin being identical at time of recording.
