- Banned
Just opened the door on a obx mannequin and the window didn’t drop in time so it hung up. Is that a very common problem? I’ve seen it mentioned here a few times. How would it be resolved?
How fast did you open the door? IMO, they should program the drop when you touch the handle like the unlock function. There is a reinitialization function the dealer needs to do to correct it. There is a SSM (not recall) pretaining to this issue.Just opened the door on a obx mannequin and the window didn’t drop in time so it hung up. Is that a very common problem? I’ve seen it mentioned here a few times. How would it be resolved?
Maybe it's for closing purposes on the mustang, but the Bronco appears to need it for opening also. Otherwise, the window wouldn't catch on anything while opening the door and we wouldn't even be having this conversation.This is a recurring comment. I went out to check my Mustang and: The window does not drop until the door opens slightly, enough for the dome lite to come on. The function appears to be aimed at closing the door, not opening it. It seems there is a design issue with the weather stripping window interface: too tight.
Don’t suppose if we could do this with forscan in running one of the relearn procedures to avoid a trip to the dealer?How fast did you open the door? IMO, they should program the drop when you touch the handle like the unlock function. There is a reinitialization function the dealer needs to do to correct it. There is a SSM (not recall) pretaining to this issue.
Funny you bring this up again. Got home yesterday and my LR hung up, same one that was doing it a couple months ago. Did the relearn in the drive and back to normal. Not sure if this is a function of a fault with a sensor in the motor or if it works off a timer in the BCM.Don’t suppose if we could do this with forscan in running one of the relearn procedures to avoid a trip to the dealer?
only one of my door’s windows gets held up on the weather stripping, have tried the window relearn where you hold down the window button for 5sec on the way down and back up
Guessing we’d have to go to a dealer to find out or is there no bulletin for this issue yet if that window button relearn doesn’t work?Funny you bring this up again. Got home yesterday and my LR hung up, same one that was doing it a couple months ago. Did the relearn in the drive and back to normal. Not sure if this is a function of a fault with a sensor in the motor or if it works off a timer in the BCM.
I noticed this on mine as well, took me a minute to figure out what was going on!Did find an anomaly yesterday, if you hit lock button on door when exiting but do not full close door you cannot unlock with the door handle , only the keyfob
