Window not dropping when opening the door
killaz05
Charles
Rockledge, FL
2021 Ford Bronco Badlands 2.7 Sasquatch
I got my bronco on Tuesday and its been amazing. Tonight, the drivers window decided it doesn’t want to go all the way up with one touch but it will go up holding the button. It also will not drop down when opening the door so it doesn’t seal up properly. I am thinking I might disconnect the battery to see if that helps but I am afraid it might need a trip to the dealer
604Bronco
British Columbia
www.bronco6g.com
There's usually a window re-set procedure for these windows. I can't recall what it is, but my Audi had it as well. Should fix your issue. Just Google "Ford window relearn process."
Werkedperformance
Philthy
www.instagram.com
Badlands 4dr 7MT
try getting in, start as usual.
roll window full down
then hold the button down for like 5 seconds.
roll window up
hold button up for 5 seconds
see if auto up down and auto drop are resumed......
seems like it lost initialization somehow
killaz05
killaz05
Charles
Rockledge, FL
Worked like a charm! Big thank you because I was worried.
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
I’ve had the opportunity to open/close several different pre-production Broncos recently. Overland Expo West & Bronco Super Cell. IMPO all of them were not functioning properly. The drop down speed when opening the door was not sufficient & if opened and closed several times the windows kinda became confused and behaved inconsistently.
Good luck, I hope the reset suggested above is helpful.
604Bronco
British Columbia
www.bronco6g.com
No problem. I would have been worried too! Glad it was a simple fix :)
KnoxGnater
Nat
Knoxville, TN
1934 Ford Roadster Pickup, Bronco Badlands
ive noticed that mine (delivered Tuesday) that they move pretty quick, no catching or issues. I think they’ve sped them up.
KnoxGnater
Nat
Knoxville, TN
Unrelated, but did you know holding the unlock button on the fob for 5 seconds drops all 4 windows? They don’t go back up, but it’s handy to air it out on a hot day before you get in.
SnowBronco
Canada
My passenger side front is the worst... The drivers side does ok. The dealership said they updated it, and an OTA update showed up on my ford pass... But nothing changed. The window drops upon door opening are still slow. I guess I'll bug them again later. Lol
Bronco21fan
Angelo
NewJersey
Check your Manuel on my 07 mustang gt there was a way to reset it if I rember bye lifting up on the window switch for a couple seconds
NotApplicable
BEVs
If that’s true how do I get the update! Lol
BradenOBX
Tim
Wheeling WV
14 Wrangler, 21 Wrangler 392
roll window up
Worked great I'm glad I remember reading this a week or so ago I searched it today and it worked great what a great thing about this forum
Albarran1235
Jose
USA Florida
2.7 v6 2021 ford bronco
roll window up
Thank you!!!! It worked for me
CowboyKid
Washington State
2022 Bronco 4DR
roll window up
Many thanks! Had the same problem with the driver’s side window not dropping then closing over the rubber gasket at the top, so as to leave an open air gap at the window’s rear edge. The rain is here! I was going nuts over this … on Day 2 of ownership! Now I can sleep tonight.
