Window & Windshield Tint Caution
Damien21
Damien
San Diego, CA
2018 A4, 2013 Tacoma
Simple word of caution:
Tinted front windows with XPEL Prime Plus 35%
  • No issues IMO with glare at night
Then I decided to tint windshield in same tint at 70%
  • It's been three days, but I may remove the tint when I take the truck back in for Stealth wrap next month. Here is my issue:
  • XPEL does not have a lighter shade of tint
  • Tint + fact that Ford ambient light sensor (see photo and same one used in Ranger) is on inside of windshield on the dash + rake of the windshield, means the sensor is not often in direct sun
  • The auto headlights keep turning on (and off) even during the day-I have the delay set to max at 20sec. I am not as concerned about the headlights being on, but when the headlights are on then both interior screens dim, and they are both controlled by the same instrument cluster buttons when the headlights are on. Changing brightness on the center 12in display does nothing when headlights are on. Even at max brightness the dim screens are annoying during the day when the sensor thinks the headlights should be on.
I like having either the daytime lights or headlights on, but the tint interfering so much with the ambient headlight sensor and the resulting screen dimming is annoying. I may try a lighter tint from 3M, but not sure. I have tinted most windshields in the past and never run into this issue, so just an FYI for those thinking about it.
Ford Bronco Window & Windshield Tint Caution Photo Dec 19, 12 13 37 PM
Hkak45
K
Illinois
21 Bronco Black Diamond
My bronco headlights go on and off a lot during the day and I don't have tint on the window. I think it's because of how dark the interior is on the bronco.
Damien21
Damien21
Damien
San Diego, CA
Thanks. I am going to give it a few weeks, but I did not notice it happening as much until after I tinted the windshield
Damien21
Damien21
Damien
San Diego, CA
There is a setting on the F150 in ForSCAN for this sensor. Hopefully The Bronco team can fid that setting. It will fix the issue.
Thanks. I am mildly hopeful. All I found the last few days was regarding the delay to switch the headlights on. I think older versions of SYNC did not allow the user to adjust, but SYNC4 does. Ran into a lot of bad news about that module having a set sensitivity/calibration and nothing can be done aside from adjusting the delay, but my fingers are crossed.
raybuck
Alex
Georgia
2020 Raptor
My windshield has been tinted 50% for roughly 6 weeks on my FE without any issues. I’m not 100% sure the tint is what’s causing the lights to go on and off.
Damien21
Damien21
Damien
San Diego, CA
That's good to know. I'm not sure what the problem is then. Had truck for 3-4 weeks without any issue before the windshield was done. I'm leaving it for now
604Bronco
British Columbia
www.bronco6g.com
Try aiming a light on it (from inside the cab) and see if it responds normally. If it does, it’s likely the tint. If not, it might be the sensor?
Just a low-tech idea that might help before you peel the tint off.
Kramku1
Council bluffs IA
Escape
Is it even legal to tint front windshield just curious hope you get to solve the problem. I leave the lights on auto myself and still waiting for my bronco
Damien21
Damien21
Damien
San Diego, CA
I believe it is illegal in CA and most other states. I have always done relatively light side tint (also illegal in CA), and as light as available on the windshield. I have never been pulled over for tint and think it needs to be egregious for a cop to stop you here.
Damien21
Damien21
Damien
San Diego, CA
Thanks, and yup it is the tint. It seemed mostly okay today. I assume given how the sun is in winter, this might be the worse time of year.
_finack
Fort Lauderdale, FL
2015 Lincoln MKZ
Personally, I'd never tint my windshield. I noticed the side window tint in my car started to get a bit blurry before I replaced it. I wouldn't feel like I'm being a responsible driver driving around at night with tint that is starting to blur everything in front of me.
unfortunate
NA
I’m wondering if it’s because you used a very high quality tint on the windshield that rejects a lot of UV so the sensors are hardly getting the same amount of UV it did before?
DrewPeakoc
Maryland, United States
2020 Toyota 4 Runner
It could be from extreme UV- do you live in an area with a ridiculous amount of sunlight? Maybe your experience is from years ago, or you're using very low quality tint, or your installer didn't clean the glass properly or, you didn't use tint safe cleaner. It could also be any combination of these.
Just my thoughts.
