Won’t start in freezing weather
International_George
George
Kirkland, WA
1980 International Scout II
Would the issue show up in Forscan? I’ve yet to try it, but this could be a golden opportunity.
George
Kirkland, WA
So Forscan shows the following DTC errors
Code: U3003 - Battery Voltage
Additional Fault Symptom:
- Circuit Voltage Below Threshold
Status:
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Passengers Door Control Unit
Status:
Module: Drivers Door Module
Code: U0415 - Invalid Data Received from Anti-Lock Brake System (ABS) Control Module A
Status:
Module: Parking Aid Module
Status:
Module: Steering Column Control Module
George
Kirkland, WA
It’s off to the dealer on a tow truck. No luck holding a charge on the battery. I bought a bigger charger and ran it to 100%. It only was 62% in the morning. I’ll post the results once the dealer gets back to me.
Rednek
Jimmy
Northern Alberta
2021 Bronco BD/2023 Maverick XLT/02 F150/68 Torino
I'm a little late to the party but a common problem is batteries being part discharged and "freezing up",take the battery out and put in a warm area for awhile to get started(they also won't charge when frozen)and will need replacement after because of plate damage.
cowman
cowman
texas
ford
George
Kirkland, WA
Well it’s a dropped valve. I guess I’m one of the unlucky ones that gets to wait for a new engine. No idea how long it will take.
chtucker
Kirkland, WA
FJ Cruiser
HOLY !@!~
SO sorry to hear this! When did you take delivery?
My FE was at FoK for some paint touchups this week and both are scheduled for the A pillar leaks.
Bodge Garage
Kris
Millwood WA
1994 Land Rover Discovery, Jeep Gladiator
I was thinking as much but bit my tounge untill it was properly diagnosed. Sorry for your troubles.
dbeyers
Dan
Denver
Toyota Highlander
HOLY !@!~
2.7L?
George
Kirkland, WA
My build date was 7/13.
George
Kirkland, WA
Also, after reading other threads I thought I’d point out that I was very diligent in following the 1000 mile break in procedure and also only ever used top tier 92 octane. Maybe the break in was my undoing.
bishop0577
Robb
Corvallis, OR.
2021 Bronco 4 door base/sqatch
I may have missed it, but what was your mileage? Do you know your engine birth date?
George
Kirkland, WA
1795 miles. Don’t have my engine birth date, but blend date was 7/12.
