Wouldn't it make more sense that the BL got the Squatch?
WuNgUn
Ontario Canada
2 door Squatched
  • Thread starter
  • Banned
  • #1
Ford made the Badlands as the ultimate offroader...
But I think, being as it's so close to Squatches anyways, it should come with the 35's...
And the Wildtrak, no Squatch and 33's
SMH
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
i think they wanted to make sure that the BL would fit in most garages.
during the NYSE bronco event, there was a Raptor that wouldn't fit inside one of the NYC garages
due to height issues.
Gamecock
SMH
Well, itā€™s better for us that you can get it the way you want it. Want 33s? You got it. Want 35s? No problem. Thatā€™s better...
TellurideBronco
Telluride
2023 Ford Bronco
You want the Bronco with the most articulation, the ultimate off roader, and less unsprung weight? Get the Badlands. You want your Bronco to have ā€œstanceā€, and you like the look? Get the Sasquatch package.
coolbreeze
Tennessee
Toyota Highlander
You want a daily driver that looks way better than the bottle caps offered on lower trims? Give us the option to upgrade to 33ā€ AT on trims under Badlands.
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
  • Thread starter
  • Banned
  • #9
The non-Sasquatch Badlands also has more articulation.
But everyone knows ground clearance comes from big rubber...
I guess with 33's,its well armored!
High Proof
Troy
2015 JKU, 2018 Panamera
Not sure I agree with that assessment. I run 35s now and I like the way they work on trails better than smaller tires. It's not just for "the look" even though I do very much like the look. The articulation difference on the squatch and non-squatch is something like half an inch. In most situations the extra tire height will probably more than make up for that. The extra unsprung weight shouldn't be a problem with the gear ratios and torque of the Bronco. I expect that taking out the fender liner or getting an aftermarket one will allow you to take out the extra bump and get that articulation back anyway.
To each their own but I don't think it's correct to say that you buy the Squatch to get stance and look.
RG7
B8 A4, 2018 Triumph Street Triple R
Good news is for those who donā€™t like the tire size their trim comes with, you can order your preferred tire size online, have a tire shop swap them out and sell the takeoffs. I get that everyone wants their Bronco to be built bespoke exactly the way they envisioned but thatā€™s part of the point of this platform: to build it the way you want. What you get from the factory is only a starting point.
Tdifonzo
Thomas
Audi S3
Is the articulation difference of 1/2ā€ measured at the spring/strut though? And would that be even more beneficial once you factor in a smaller tire that would already have more movement? Iā€™m honestly asking. I have no idea. I guess none of us do yet until we see it. lol
mostly harmless
Austin, TX
2012 RAM 1500
Ford is giving you options. Not everyone prefers 35ā€™s. If the BL came standard with 35ā€™s they would just charge more anyways. Iā€™m glad to have the 33ā€ option
Gamecock
The extra 10mm of articulation is basically meaningless when you compare the advantages of a 35 over a 33. It would be significantly more capable....if you have ever gone from 33s to 35s, the difference is pretty obvious. 10mm in upward articulation would go unnoticed.
