2021+ FORD BRONCO TAIL GATER REVERSE / CHASE LED Light Kit
MandRautomotive
Mikhail
CA
  • Fits Ford Bronco Models without a trailer hitch option
  • 12in light bar, choose (amber or white)
  • 40w, uses 8 * 5w CREE CT-E 5w LEDs which produce right under 4000 lumen
  • Perfect sleek kit in the plastic bumper cutout.
  • You will need to extend the wiring yourself to your AUX switches
Ford Bronco 2021+ FORD BRONCO TAIL GATER REVERSE / CHASE LED Light Kit Reverse
Ford Bronco 2021+ FORD BRONCO TAIL GATER REVERSE / CHASE LED Light Kit Light Off
Ford Bronco 2021+ FORD BRONCO TAIL GATER REVERSE / CHASE LED Light Kit Light ON
Ford Bronco 2021+ FORD BRONCO TAIL GATER REVERSE / CHASE LED Light Kit Day off
Ford Bronco 2021+ FORD BRONCO TAIL GATER REVERSE / CHASE LED Light Kit Contents
MandRautomotive
MandRautomotive
Mikhail
CA
Here is an installation mounting video
MandRautomotive
MandRautomotive
Mikhail
CA
Love this idea. Any workaround for those with hitch?
I always keep looking for ideas. This kit is in place of the hitch and looks great with that bumper indent for it. We will keep looking to offer something elses like always
j_anderson
Fort Wayne, IN
www.instagram.com
You could use something like this?
Ford Bronco 2021+ FORD BRONCO TAIL GATER REVERSE / CHASE LED Light Kit Screen Shot 2022-02-17 at 12.28.33 PM
I was thinking about using a different version of one of these as a rear fog light but something like this would work to provide extra light when in reverse. you'd want to put in a weather proof connector on that white wire so you could easily disconnect it when you need to use the hitch
MandRautomotive
MandRautomotive
Mikhail
CA
Got another idea. Testing it over the weekend
WuNgUn
Ontario Canada
2 door Squatched
So... Do you actually have a link to the kit, or....? 🤷
Or am I blind.
I'd be interested in that bracket. I wanna go with a red LED rear fog setup.
MandRautomotive
MandRautomotive
Mikhail
CA
MandRautomotive
MandRautomotive
Mikhail
CA
What do you guys think of this setup. Works perfect with 35s and probably 37s
MandRautomotive
MandRautomotive
Mikhail
CA
How is this for a chase light or reverse light setup
Just_Jim
Minnesota
2021 Big Bend
Is there anything funky needed to add backup lights with the LED tail light option?
Can you just tap into the existing harness at the housing or do you need to do something else like with the interior lights? Like using pin #2 on the 7 pin harness for example.
helifino16
Ron
Mount Sinai, NY (Long Island)
Ford Bronco 2021+ FORD BRONCO TAIL GATER REVERSE / CHASE LED Light Kit FB_IMG_1646007636105
I understand that the issue with anything that plugs into the Trailer Harness ends up disabling the Rear Parking Sensors (not sure about the Blind Spot monitors also). Of course, not a problem if you don't have either of those, but many of us will (or do) have them.
j_anderson
Fort Wayne, IN
www.instagram.com
You wouldn't plug this into the trailer harness. you would just use the pigtail to adapt it to the factory harnesses since this harness connector is weatherproof and easily detachable
