220k Ford Pass Rewards Points for early reservation holders?
EJC
texas
Beater
How early does the reservation have to be? I am 7/19/20 and never got an email about 200k points.
Dcbmstew
Cindy
MN
Yep- 262K on a BaseSasquatch. Dealer can only process the points that show up. Ford Pass has to send them first. 20K , 200K or both call Ford Pass if you got an email. Why leave money on the table ?
I called Fordpass yesterday and they told me the additional points were on my profile and in my "member portal" and that the dealer would have to go in and redeem them. Is this the same information you got?
SolidSnake
Dante
No
That's exactly what you have to do. When I got my bronco I only got the points for getting a new car and my dealer said he didn't see any more points. I forwarded him the email and a little later that day the 220k points showed up
Dcbmstew
Cindy
MN
Ok, so the dealer had to manually do something?
SolidSnake
Dante
No
Yea. I waited a few weeks to see if they popped up since only the 42k points showed. I called ford and they said the dealer has to pull the points into the account
Dcbmstew
Cindy
MN
Ok thank you! I have sent my dealer everything, so hopefully they figure it out.
1975U15
2019 F-350 SD, 1975 Bronco
Following. Anyone having success?
Finally got my FordPass to connect and activate with Bronco yesterday. Ughh. Multiple attempts. Delete app. Disconnect battery. Had to do a FordPass reset in vehicle to get it to work. Emailed Hunter with Granger last night and this morning he confirmed the 220k points would now show. Now have my 262k points. I never talked to anyone at FordPass. Just got vehicle to activate finally and emailed Granger to push points.
He said there are a lot of folks with same issue I was having with activation. There's a thread somewhere I used to follow troubleshooting steps.
Early Reservation with Mod top originally.
Boxer4
TRUCK
Yes
Felix808
SRV CA
As a Day 2 Res, I could have sworn I had this email & now can't find it 😟
FellowM3
Northern NJ
Current: 22' Braptor, 2020 BMW M340
I never got the 220k ford points email. I was a early res holder (7/14/20) and had mod top ordered.
What can I do to get this straightened out?
JohnnyBronco
Pennsylania
X4
Read the post that says contact your dealer.
FWIW, there are two separate amounts and 2 separate original emails from Ford.
20,000 for being an early res turned into order. No order no points
200,000 for giving up hard top in lieu of a soft top only.
Now I had the dual top (modular and soft) on my order and dropped the mod. I cannot comment on if one only had a hard roof on order with no soft top and then switched if the same points pertain
  • Like
Reactions: Cat
HorizonHunter
Joseph
Chapel Hill, NC
Grand Cherokee Trailhawk
Have we ever determined what Ford deems "early" reservation holder? I'm 8/5, can't find any emails in my history about points.
Orjeepguy
Oregon
Bronco, Black Diamond
This has nothing to do with what top you ordered. We have a two door and received the 220k email. Two door only had one option for a top.
1975U15
I can confirm as an original WT order(Mod top standard) I received 200k points for switching to MIC.
Edit: To clarify. When the Mod top was made unavailable and WT/2drs had to go MIC or delay order. Switch is a bad choice of words.
Dcbmstew
Cindy
MN
I'm still waiting on the 220,000 but somehow I also received 11,000 user appreciation points. May be something you want to checknout
Thanks for your help with this. I now have 273,000 points in my account!
  • Like
Reactions: Cat
