Can FORScan make high beams control fog lights?
Alfie623
Alfie
Newburgh, NY
1983 Bronco
I’ve already set fog lights to “enabled” with high beams through FORScan but the fogs won’t come on if fog lights aren’t already on. Does anyone know of a way to have the fog lights function with the high beams?
I’ve bought a kit for my Silverado that does this with a diode but I was hoping there was a FORScan setting that I wasn’t aware of that could make this function.
drew707
Ford Explorer
Fog lights enabled with high beams (Bambi mode) means that if the fog lights are already on they will stay on. It’s a regulatory thing for them to shut off if you switch to high beams normally. I don’t know of a way to have them come on just by switching to high beams.
Side note the new Ranger and Everest have matrix headlights and god I hope the Bronco refresh gets them. They’re truly amazing
Alfie623
Alfie623
Alfie
Newburgh, NY
1983 Bronco
Gotcha. Thank you.
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
On my 2017 superduty there was a way to remember fog light status so if you have them on they would come on again when you start the car. Since I don’t have fog lights (mod bumper) I haven’t looked to see if the setting is there on the bronco.
drew707
Ford Explorer
Yes there is a fog memory, so long as you don’t manually turn the dial to off they will remain on (when the setting calls for it) if they were on the previous time you drove the vehicle.
