- First Name
- Phil
- Joined
- Jul 21, 2020
- Threads
- 41
- Messages
- 4,425
- Reaction score
- 14,627
- Location
- IN
- Website
- www.ruxerparts.com
- Vehicle(s)
- Fords
- Your Bronco Model
- Badlands
Not to sound like an ass but 3/8 Milwaukee impact, impact swivel, impact torx(+) bit, ratchet strap and this becomes a non issue. Just make sure you pull the shaft after hooked up to tow vehicle or wheels are chocked.
Rear Driveshaft
Special Tool(s) / General Equipment
Removal
NOTE: Removal steps in this procedure may contain installation details.
Rear Driveshaft
Flat Headed Screw Driver |
Tire Lever |
- With the vehicle in NEUTRAL, position it on a hoist.
Refer to: Jacking and Lifting (100-02 Jacking and Lifting, Description and Operation).
- NOTE: Tighten the driveshaft flange bolts in the cross pattern.
- Remove and discard the driveshaft flange to drive pinion flange bolts and the retaining straps.
Torque: 35 lb.ft (48 Nm) - While installing the rear driveshaft, make sure that the driveshaft end with splines is towards the rear axle.
- Index-mark the driveshaft flange to the pinion flange to maintain alignment during installation.
- NOTICE: Do not remove driveshaft from the pinion flange by pulling on the driveshaft tube. Damage to the CV-joint can result.
Using a large flat headed screwdriver or tire lever, separate the driveshaft flange from the pinion flange.
Use the General Equipment: Flat Headed Screw Driver
Use the General Equipment: Tire Lever
- NOTICE: Make sure that the driveshaft is supported with suitable retaining straps.
Support the driveshaft.
Remove and discard the driveshaft flange to transmission flange bolts and the retaining straps.
- Index-mark the driveshaft flange to the transmission flange to maintain alignment during installation.
- NOTICE: Do not remove driveshaft from the transmission flange by pulling on the driveshaft tube. Damage to the CV-joint can result.
Using a large flat headed screwdriver or tire lever, separate the driveshaft flange from the transmission flange.
- Remove the driveshaft.
- To install, reverse the removal procedure.
