Boxer4
TRUCK
10-7-20 Edited
ANSWERS:
1. Max tire size with standard suspension on Base - BB- BD -OB
32”
2. Suspension Difference on BL vs Sasquatch how? -Will 35' tires fit BL
Sasquatch has stiffer springs and longer shocks. There is no “ spacer”
3. How is the Sasquatch lift done? Stiffer springs?-Spacers-Longer shocks? See #2
4. BD-BL is rubber washout in 2nd row floor, seat backs and cargo areas?
Carpet backs on 2nd row- rubber “mat” in cargo area
5. Does Sasquatch have upgraded front Diff M210
6. Where is the 7sp made
7. In 2021 will there be- 37" tires-Raptor-Warthog-Hybird
No
8. On HD bumper is there a Prewire for Foglights
No
9. Does OB Sasquatch have running boards
Should
10. Is the dash production level
11. Sound deadening available on all hard tops
12. Start- stop button on all trims
Yes
13. 2" stand alone lift or 37" tires & lift with Ford Preformance
2” lift- not at this time
37” is different setup than Sasquatch
14. Will Man-Sasqautch have Trail Pedal
No- Trail pedal required 2.7L and that requires Auto
15. Signature lights on BB
Yes- stand alone option
16. Badge stickers removable
17. Eco Boost intercoolers different for Bronco because of trail- low speeds?
unknown
18. Will other Trims offer Sway bars
BL -FE
19. Back A/C Vents on all 4 door- Flooding with low vents washout
Should be no problem
20. Tow package MAX for 4 door above 3500#'s
No
21. 2.7 L Plastic oil pan protection
Bash plate
22. Hard Top colors- Modular top parts explained
23. Wheel Bolt Pattern- Sasquatch wheel offset
24. Cutout doors on 4 door
25. Weight of 2-4 door Clam shell MIC vs Painted
Two person job
26. Will 37" fit with 3rd Brakelight
True 35 x 12.5 were tight against it on the “ Overlander”
27. Will LSD available
28. Models with trail cams
No all
29. Models with Mollies
Washouts
30. Is the picatinny rail going to be available for all models
Yes
31. Future Colors
32. Beadlocks on BL 33"
Yes
33. Secondary battery rough in
No
34. Seat height
About 38” on the BL on display- that was a behind the rope measurement.
was at least 3” + above the 33” tires
35. Head Height
36. Rack Removal Time
10-15 minutes
37. Center armrest movable
No
38. Trail Sight Heights
As guess as seat height- about 51”
39. Shorter Drivers- pedals
No
40. Soft top Demo
Video in the works
41. Video of accessing back seat of 2 Door- footwell size -seat slide etc
Now on Ford’s radar
42. Rear Window- how wide and how high
43. Next Dates
Unknown
Lakelife36
Ben
Interior of BC
Are they considering (or actively developing) an optional max tow package, even if it is restricted to four door models and has a stiffer suspension?
BroncBro
2019 Tacoma 4x4
What questions would you ask if you could attend Bronco SuperCel East?
Im not sure if there’s many questions left that Ford won’t say that it will be answered in the B&P, but.....
- Is Velocity Blue going to be a regular availability color or late?
- Are 37s going to be a factory option in 2021?
- What color options and/or factory options will cause a later than normal availability?
Garemlin
Delaware
1. When getting the Black Diamond or Badlands with washout interior, does the rubberized flooring continue into the cargo area and rear seat backs??
2. Is the picatinny rail for the dash going to be available for all models??
3. Will there be an option for an AC power outlet in the cargo area??
4. On the Ford site it lists the signature lighting as being an option on the Big Bend. Is this a typo or will it be available as a stand alone option.?
5. Will 33" fit without a lift on the OBX, Black Diamond, Big Bend and Base??
Raptor911
Raptor911
Broadlands, VA
Does not matter what we suggest to be asked and the same stupid questions will be asked over and over again.
Ask some simple facts that matter:
- Can you confirm the wheel bolt pattern?
- what is the offset of the saquatch wheel?
- will the 2.7 have a plactic oil pan?
Please just ask simple questions that they can be answered instead of, will there be a white top. PLEASE!
Most of the questions peeps are suggesting will be answered when the B&P is released and thus they will not answer them
Ride Em Bronco
Al
Pittsburgh, PA
2008 Jeep Liberty Sport
For the Big Bend, under the Optional Signature Lighting it shows that the LED Headlights are included. Will Ford also make the LED Tail Lights an option? Or if the BLISS option is chosen, will the LED Tail Lights be included?
