Installed some inexpensive fog lights and ditch lights.
Mountain Mike
Sylva NC
Jeep Rubicon
I was wanting some ditch and fog lights. So after shopping around I found these pod lights at harbor freight and some fog lights at amazon. The pod lights are $22 a piece and the fog lights were $30 for the pair. Ive had them on for a couple weeks and so far so good. Both products have great ratings so I thought I would share in case someone else has a budget.
https://www.amazon.com/OFFROADTOWN-Driving-Lights-Bright-Warranty/dp/B078RDJCPC?ref_=ast_sto_dp&th=1
https://www.harborfreight.com/3-in-led-flood-light-64322.html
Ford Bronco Installed some inexpensive fog lights and ditch lights. light 3
Ford Bronco Installed some inexpensive fog lights and ditch lights. light 2
Ford Bronco Installed some inexpensive fog lights and ditch lights. light 1
1970AMCAMX
Robert
Titusville, FL
F150, AMC AMX, DF Goblin
The Harbour Freight ones are actually pretty good, not as bright as the popular ones that cost at least 10 times as much but good enough for normal use.
Robbie_S
2022 Bronco OB Cactus Gray
These both look good! How was the install of the lower fogs? Did you just remove the factory fogs and trim the plastic until they fit?
zjc26138
Zach
Steubenville, Ohio
2021 Bronco Sport BB
I like them!
I'm interested in the harbor freight lights. I wonder how hard of install with having aux switches?
tynamo29
Tyler
Columbia, SC
Bronco base
Your post inspired me today! I drove over to Tractor Supply Company and bought some inexpensive ditch lights of my own. I have not wired them in to the aux switch yet, but they look great mounted on.
Ford Bronco Installed some inexpensive fog lights and ditch lights. 499FBC29-94F1-4A1C-A59A-6017C0BF24AB
Ford Bronco Installed some inexpensive fog lights and ditch lights. CB07342B-217B-4EF6-B3DE-A27EEC2A4310
Pepperenavich
2018 F150 Fx4
What bracket did you use for the ditch lights?
Dmorty217
Derek
Venice FL
Camery
I purchased Nilight ditch lights and led bars for mine. Work great and I have no complaints.
Mountain Mike
Mountain Mike
Sylva NC
Jeep Rubicon
On the base Bronco you just need to cut out two squares using a template and simple wiring. Here is a video to help
Mountain Mike
Mountain Mike
Sylva NC
Jeep Rubicon
Mountain Mike
Mountain Mike
Sylva NC
Jeep Rubicon
I like them!
I have the aux switches and it made the install super easy. Just make sure to use some heat shrink tubing to keep the connections water tight.
frkrican2004
freddy
New York
looks great! did that bracket come with the ditch lights you installed?
da_jokker
Jeep Wrangler JKUR
I may need some fogs for my aftermarket bumper. Sounds like those harbor freight ones might use 1.25 Amps? Which is less than the 3 amps the stock fogs pull (so I can keep them wired to the factory fog switch)
The only thing is I wish they were IP 68 i stead of only IP67. Being low in the bumper is pretty susceptible to submersion.
