Westin XTS bumper has made parking sensors overly sensitive
AZMikeL
AZ
Swapped my capable bumper for a Westin XTS I picked up from a member on here. Moving the sensors and harness was easy enough (thanks to the miracle of zip ties), but now they are overly sensitive.
Seems like they beep if something as small as an ant crosses my path. I carefully marked each one to make sure the orientation was correct, so I'm pretty sure that's not the issue. They fire at every little thing on the ground in my path - including the concrete section in my driveway that crosses the wash.
My best guess here is that they are pointing downward a bit causing them to trigger. Any suggestions? Any of you other folks running the same bumper run into this?
