What’s the most bulletproof bronco build you can get?
MEAT_GOD
Kuwait
22 Ford Bronco 2dr, 15 Maserati Quattroporte
This is the first I have heard that the four door bronco has more problems than the two door. Can you be specific as to the problems you
It's a major problem in which moar door Broncos tend to be confused with minivans, which is a serious case and is extremely distraughtful for minivan owners. :(
Area51BS
Ron
Badlands non SAS 4dr 2.3
I can guarantee with 100% certainty that there will be no 6G Broncos that are alive 50 years from now, except for very rare units owned by individuals with lots of money. And the reason is, as you stated, all the electronics. There will simply be no spares for electronics past a 15 year or so lifetime, and unlike mechanical parts, you cannot replicate them unless you have a $1B semiconductor plant, the original design files, and the original fabrication process.
Ask me how I know. I have a god damn $3000 Samsung range in the kitchen that is 8 years old. Works perfectly except the friggin touch screen broke. And guess what, there are no spares in existence anywhere in the world. I now have a $3000 paperweight because of a $100 electronic part.
Couldn’t agree more.
JohnnyBronco
Pennsylania
X4
The soccer moms will get over being distraught after 3 glasses of Chardonay.
Meanwhile my 40,000 mile 2021 OBX 4 door 2.7 advanced is (unless someone else posted higher) the most bulletproof Bronco in this thread.
Eljohno
Illinois
Silverado
That's not a Bronco, only 2 doors are Broncos! That's a Flex with big tires!😜
Tricky Mike
21 Bronco
Or less you buy a Toyota 4 Runner then it’s bulletproof.
Toyota is not what they were anymore. Plenty of problems.
It seems to me like the 4drs are more likely to have window indexing issues, but that might just be because there are far more 4drs out there.
I could see a modular electric conversion package coming out in the future where you can rip out everything from the original car and start over. The modern equivalent of dropping a carbureted small block Chevy into anything and everything.
brkdncr
Southern California
Toyota 86
I think the drivetrain will be the biggest issue. Everything else can be ripped out. Even the engine can be swapped, but finding something to work or replace that 10spd may be a problem.
the manual trans may have an advantage in this aspect.
Sherminiator
CNJ
2022 Ford Bronco Big Bend
So your comparing a range made by a cell phone manufacture to a car for reliability when it comes to electronics? Why spend 3K on a computerized range anyways? Are you going to turn on your range to preheat the oven remotely? Spending that much on something that just needs to bake/warm up food is downright stupid.
There are a decent amount of cars from the 1980s with some of the first gen electronics still running on the road that are hitting 40 years old.
While something like the 5G modem in the car might not work 50 years from now, I'd say the displays and ECU in the Bronco should have a reasonable chance of surviving that long.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
As the least reliable Bronco here I can say I trust the 4cylinder and auto transmission recommendation. I would also say the part time transfer case is more reliable, auto cases have had people lose 4wd.
I will say that not having dual zone ac and other things has drastically increased my long term reliability. Keeping the sensors and crap working on a 10-15 year vehicle is a full time time job.
BigMeatsBronco
Allan
2021 FE 2 door
the Raspberry PI can replace your modules....in the future we will have all kinds of retrofits to fix antiquated electronics....so I don't think this is correct.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
By then you will have electric motor and a battery lol.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
Yep, and BigMeatsBot will diagnose, repair and retrofit before any of those OTHER bots get outta cryosleep... lol
timhood
Tim
Several
I’ve been trying to keep up with the problem spots on the Bronco, preparing to finally buy my own. The two biggest issues I’ve seen have been the 4x4 cutting out (overheating error) when in sand/wheel spin that appears to be on models with the advanced 4x4, and the 2.7 seems to have a lot of problems.
With that being said. What other major/common problems does the bronco have to be aware of, and how can they be solved by either factory or aftermarket solutions?
At this point I’m thinking a Black Diamond, non sas, 2.3, mid package.
You're going to get a million different answers. Assuming your Bronco will actually be used off-road: Badlands or Wildtrack unless Raptor is out of your budget. That's the short and easy answer. If you're thinking Black Diamond, I'm going to guess that there's a budget in play here. If Badlands exceeds the Budget, BD would be the next-best choice.
2.3 vs. 2.7: I can parrot any number of arguments for or against either. I have the 2.7 and have zero qualms about that decision. Just go for whether you want more power or slightly better fuel economy, I guess.
We've been off-road at least 20 times in the first year and haven't had any issues. I do like having Advanced 4WD so that I can have 4WD in rain/snow.
