What’s wrong with my gauge cluster? Different Font Used?
honorarysail
2021 2DR Bronco
Ford Bronco What’s wrong with my gauge cluster? Different Font Used? IMG_1388
hey everyone! bought a used 2021 ford bronco big bend with 40k miles for around 29k, thought it was a great deal but noticed something peculiar—the gauge cluster text is different from everyone else’s? It came from Canada originally imported into the U.S., so my only hunch is that a faceplate swap to mph was needed? It’s bothering me though because the mph text isn’t fully lit up, any help, insight, or fix is greatly appreciated thank you!
DriveAllNight
Dan
N.J.
One Very Cool Ride
Smaller font, more numbers.
Weird that it would be different if its OEM. I would think Canadian Bronco owners would have mentioned this, I'm thinking aftermarket parts.
Gilligans_off
Vince
Canada
2022 2 Dr Bronco Badlands Sas/lux
Exporters have to change the cluster to read MPH when they import them to the States. They must've used an aftermarket cluster or some kind of overlay
2023bronco
usofa
2023bronco
Consider it a rare option. The analog speedo is worthless. I NEVER look at mine. I think in time you'll find your rare gauge doesn't bother you, unless you're in the 1% that reads the analog speedo instead of the humongous digital one.
BadmansSAS
Tampa FL
2023 Bronco Badlands Sasquach
Probably from a bronco sport?
DarthLincoln
Chuck
Northern California
1999 BMW M coupe, 2023 Ford Bronco Badlands 2dr
WTH? The numbers dont have standard increment. It alternates increasing by 10 and then increasing by 15.
I think you’re right - looks like a faceplate swap to convert kph to mph.
Braaap
NJ
Outback
If you're interested in upgrading the gauge cluster, Panda Motorworks has a complete plug and play Bronco Raptor cluster. Very cool but expensive.
TheShark
'23 Bronco 4DR Wildtrak,'24 Maverick Lariat Tremor
Looks like a real hack job. I'd check eBay or the boneyards and see if you can find a speedometer cluster.
BigMeatsBronco
Allan
2021 FE 2 door
You probably just figured out that they changed the mileage while they were at it
