- #31
How is the rubbing without collars? Are you going to be able to get near/full front travel along with steering locked?39s on, next up lift collars and suspension pieces.
full lock steering will rub.How is the rubbing without collars? Are you going to be able to get near/full front travel along with steering locked?
I've got the DV8 as well - still no Braptor (5/29 build week). What size replacement bolts (M5/M6? Length?)did you get? I was planning on using a nylon washer/spacer between the bracket and the bumper for the reason you mentioned - and took it a step further and put rivnuts in the holes for the license plate to not have to worry about nut and washer.Got my plates in so Installed the DV8 front license plate bracket. I like how it sits but a couple things that could be improved:
1. Supply two longer screws for where the bracket attaches to the bumper. The factory ones are short and recessed.
2. The clearance of the top two holes in the bracket from the bumper donβt really allow enough space for the supplied bolt/nut. I just zip tied to avoid scratching up my bumper. Other than that, daddy likey.
here is 37 vs 39 comparison. also the spare fits
Any tricks or tips for a good application? Waiting to install mine in a few days.Kind of a pain to put on, but overall itβs not bad.
Maybe try the wet method when installing? Not sure how well that would work though since it is such a small space to push all the liquid out.Any tricks or tips for a good application? Waiting to install mine in a few days.
Curious. Are you concerned about the strength of the factory arms? The Foutz ones are beautiful and baller, but seem like overkill. Going to get a color anodized set?next up: ... rear suspension arms
More of the design then the strength.Curious. Are you concerned about the strength of the factory arms? The Foutz ones are beautiful and baller, but seem like overkill. Going to get a color anodized set?
Can you expand? Design as in functionality or design as in aesthetics?More of the design then the strength.
i like overkill i have full monoball suspension on my GT3 so may as well do it to The braptor (aka dirt gt3) as wellCurious. Are you concerned about the strength of the factory arms? The Foutz ones are beautiful and baller, but seem like overkill. Going to get a color anodized set?
