What kind of modification needed to install 7.3L Megazilla crate engine my 2 door Bronco?
OtisFE
Otis
Alexandria, VA
2022 Bronco OBX
You will need a Genie in a bottle and all 3 wishes.....
Ground_zero298
Scs michigan
Lmao. Pretty much everything but the body panels and the steering wheel. I’d start with a new frame.
So money, a custom shop, and probably a year in a half. It’s doable.
swooshdave
Portland, Oregon
Mustang
From watching the guys put the Coyote in it doesn't look like much. I suspect the Godzilla is way narrower and will give you more room. I would probably try to figure out how to use the bigger transmission/transfer case from the F150 as the Bronco one isn't rated that high. I believe they are about the same size.
https://www.youtube.com/@No_Traction_Faction
Other channels threatened an engine swap but they all chickened out, ahem Emilia...
jasonkosi
Chilliwack, BC, Canada
I think one of the biggest reasons was due to the electronics. Swapping an engine in physically is one thing, but getting all the engine/trans electronics to play nice with the BCMs and all the other tech is the issue.
swooshdave
Portland, Oregon
Mustang
I think with any swap using modern components you have to expect not everything to work. There may be some gaps. Does the ECM actually need to talk to the BCMs?
Dmorty217
Derek
Venice FL
Camery
22OBX
Bryan
Hartford, AL
Every time an engine is announced there is a thread…what would it take? If you have to ask you probably don’t want to be the first to attempt. Anything is possible with time and cash and in this case lots of both.
Evolkidbell
Northern Colorado
1966 Bronco, 2013 F-150
I think it safe to say "A Lot"
HotdogThud
mk6 gti, '21 MoarDoor
Well, given how big that engine is, I'd say you're going to want to start with some nice wide fender flares.
FUB6G
Seattle
Fords
Those crates are pretty good size, probably wouldn't fit even with the back seats folded down.
Hope you sprang for the tow package, that way you could put it in a trailer.
helifino16
Ron
Mount Sinai, NY (Long Island)
Now that the challenge has been posted, SOMEONE will figure it out. There will be no shortage of 'Franken-Bronco's out there with any kind of configuration. If you can dream it, someone will make it happen. (supercharged, 4x6, 2' lift kits, 50" tires, the list is endless) Nothing would surprise me.
