Year 23 Factory Sub Delete - Is amp there already and I can just add a sub?
dingle87
Reese
West Suburbs of Chicago
2019 Ford Explorer XLT
Just noticed that kicker sub is on sale at Crutchfield right now too. Win Win
Karl_in_Chicago
Karl
Chicago
Reading on other posts the 4 ohm is the better choice for less muddy and less boomy distortion. That’s what I’m after. Tighter sound. - seems like 4ohm is better for me with the fusion amp
Went back and looked at my invoice and turns out I bought the 4 ohm as well. Been a while. :)
Mscdman
P
Denver
OBX
Hopefully will work well with my 6.75 kicker rear speaker pods and this 6.75 sub setup. Only looking for a little bass and richer sound.
Based on what km reading I just need to forscan and enable the sub and turn off the eq setting to wake it all up?
Karl_in_Chicago
Karl
Chicago
The IT person in me advises you to make one change at a time. It makes debugging so much easier if/when issues are encountered.
they're just little push pin things. Your local Ford dealer has them or buy some off Amazon ahead of time. Not so much tabs fixed to the panel you will regret breaking. At least Ford didn't set us up for failure like that. Easily replaced and fixed to be honest.
There are some pieces of that panel that are plastiwelded together. And it's easy to break the plastic rivets out if you manhandle the thing too much.
Granted, not terrible to just plastiweld or glue them back together. But you really don't want to go back there more than once - every time you go monkeying with the panel, the chances of something breaking goes way up. Just the way those damn plastic snap tabs work - they aren't meant for repeated removal, just easy installs.
It's a royal pain, especially with the newer TSB clips in there, but be patient and don't try to take short cuts and you can get it out. Getting that large rear cargo panel off is far and away the hardest part of the job, but not impossible nor overly difficult. And if anything breaks (and it's almost guaranteed if you are doing full amp/speaker/sub install that something will break somewhere), a) it probably will be in the back where it isn't visible anywway, b) go get some E6000 glue and that will fix almost anything and c) a bag of replacement clips.
Karl_in_Chicago
Karl
Chicago
. . . all that and a bag of clips :LOL:
va011101
Andrew
Richmond, VA
2023 Bronco
I think you will be happy with the added subwoofer. It’s a substantial improvement.
Mscdman
P
Denver
OBX
I’m ready to movie forward. But man that rear panel has me spooked
RoccoG
Rocco
Audi
Does anyone have a part number or reference photo for the ford fusion amp?
