0-60 Times
Thed
Ben
Raleigh, NC
It's not why I'm buying it, or why anyone is buying it....but it's also nice that it won't be a "pig" on the street.
I guess... They're both turbo engines that'll have plenty of midrange torque. Neither will necessarily feel slow DD'ing them. It's whatever to me, I have other machines to scratch the speed itch.
GaryB2220
Gary
Wellsboro PA
'99 4runner, '10 Town & Country
BamaGrad
Missouri
Toyota 4Runner
Is anybody more familiar with Wrangler’s and their issues worried about rollover risk in a bronco with the 2.7? I was always under the impression that two door versions of these types of cars were more rollover prone due to the shorter wheelbase. Car right now is much longer and much slower (4runner) and I don’t know if it’s a stupid thing to be concerned about with the extra power, driving skills aside
Cheshire
Steven
FL
4Dr Bronco BaseSquatch 2.7L
I would not be surprised at all to see a Sasquatch 2.7L with the 4.7 gear ratio to do 0-60 in under 6 seconds. It has gobs of torque and a very steep gear ratio.
Car and Driver record Zero to 60 mph: 5.9 sec in a 2019 F150 SCREW 4x4 with the 2.7L. I could not find the rear gear ratio on the truck(which has a massive impact). Considering the Bronco should be lighter and have steeper gears I would expect a better time.
I'd be surprised as shit if the Sasquatch 2.7L will do this! Acceleration or lack there of and deceleration are the two main reasons I'm NOT buying the Sasquatch package. Performance numbers acceleration and braking will be much worse on any trim 'Squatched'.
I guess a Base 2.7L with 30" road tires will be fastest. Big Bend and Outer Banks should be right behind on un-aggressive 32s. Black Diamond should be right behind. Things start to slow down with the Badlands aggressive 33s. Once you've gone up to the heavy Squatch setup with the large diameter, you're laggin far behind the Base. Squatch with the 2.3L, forgetaboutit.
If you like zipping around like me, don't Squatch.
ramblinwreck
Georgia
`22 Wildtrak, '21 Wrangler Rubicon 4xe
That might be true if all packages had the same gear ratios. The Sasquatch package comes with much steeper gears.
Rogues Gambit
Eatontown, NJ
'19 Ram Rebel, '07 A4 Quattro
Yeah, definitely not a pig, its just the Beast
Wranglers more a Boar anyway
SarcasticDOCTOR
Cole
Ohio
Mustang
I have thought about this too. I’m hoping given a little but wider track and heavier sway bars that hopefully we’ll be a bit more stable... in theory ?
bluesun68
Havasu
raptor, velar, f-type
For everyone saying it doesn't matter have you ever been on a two lane road behind a jeep, subaru, or RV? The twistier the road, the shorter the zone to pass.
lowmpg
Ryan
Maryland
F350
0-60 has zip to do with passing speed, and in a TT vehicle, the curve is much better set for passing.
Used2jeep
Massachuvian
2007 Crown Vic P71
Used2jeep
Massachuvian
2007 Crown Vic P71
