Am thinking about removing the stickers and replacing with chrome "Bronco" script badging. For those that have done the same, any advice on the sticker removal? Also, did you get your Bronco badging at the Ford dealer?
Thanks Chris. Hair dryer on low heat setting looks like the way to go...I used a heat gun on its lowest setting and gently pulled my emblem off. Be careful cause too much heat will stretch the decal. Hair dryer might work better. Also too much concentrated heat can affect the paint if youre not careful.
As for the script emblems order them from Amazon <$20
Just removed mine about 5mins ago and used one of them to dress up the Bronco Off-Roadeo yeti I hadThanks Chris. Hair dryer on low heat setting looks like the way to go...
Might look good on m y new growler...Just removed mine about 5mins ago and used one of them to dress up the Bronco Off-Roadeo yeti I had
