An open letter to Mike Levine et al.
Lakelife36
Ben
Interior of BC
To whom it may concern,
I'm writing regarding the currently-stated maximum towing capacity of the 2021 Bronco at 3500lbs. While the Bronco is a purpose-built off-road vehicle, and prospective buyers should not have expected the 7500lb TC of its Ranger l, I for one am disappointed that Ford has not been willing and/or able to engineer it to tow at least 5000lbs in any build. This is despite two wheelbases, three engine/transmission combinations, two suspensions, and no fewer than four rear differential ratios. I urge you to consider developing a package capable of towing at least 5000lbs, even if it is limited to certain builds.
One word of warning though: the Bronco at its heart is an enthusiast's vehicle, and you have already disappointed many of us by not offering the enthusiast's transmission with the enthusiast's tire/suspension package. If you are willing and capable of offering a package with higher TC and it is not available with the manual transmission then this disappointment will deepen even further. Please consider your mechanical limitations carefully and do not succumb to the whims of those who may not fully appreciate their audience.
Yours in Bronco
aplm7
Andy
Vacaville, CA
2023 Bronco Wildtrak 2 door
The problem is, while maybe only a small percentage, 5% of the design team was people like this:
Ford Bronco An open letter to Mike Levine et al. 1596321868564
All of the marketing -- and package combinations were composed and executed by folks like this:
Ford Bronco An open letter to Mike Levine et al. 1596321914249
Ford Bronco An open letter to Mike Levine et al. 1596321940870
Who also created marketing for all of Ford's other stuff, such as this:
Ford Bronco An open letter to Mike Levine et al. 1596321751050
So I would be surprised if more than 5% of those who actually worked on the release were the 4x4 offroad user type.
Zeta
GA, USA
1997 Jeep Cherokee
So ignoring the "hilarious" second post, I don't think the chosen MT would be able to handle 5000 to 7500 lbs towing if it's not even rated to mate up to the 2.7 V6. Or if you did go ahead and rate it for that, you'd have reliability issues.
Lakelife36
Lakelife36
Ben
Interior of BC
Interestingly Magna rates the 7MTI550 for up to 405lb-ft of torque, which is pretty much bang-on with the projected output of the 2.7L. This may be far too close for the third guy in aplm7's post, but quite possibly actually good enough. Magna also rates it for up to 22,000lbs of GCWR, so even the people in people in aplm7's first and second photos should be capable of doing the math to allow it for 5000lbs towing.
EvlNvrDys
Hunterdon County, NJ
It's a bronco, you shouldn't be towing anything offroad. You need an f150
Tell that to the FSB owners that could tow 7000 lbs.
Point is, it's our Bronco to do how we choose, God willing that means being able to tow.
I'm about done with people who say... You don't need a Bronco... You need X. Save it for someone who cares.
BroncoJay
Iowa
Tacoma
What does our (broncos) competitor- Jeep typical tow package rating?
I’d look it up but - yawn ? it’s Jeep..
Squatch
Miami
Lakelife36
Lakelife36
Ben
Interior of BC
Send it if you want but the second paragraph reads like you’re Bronco-splaining the Bronco to the guys and gals who designed the Bronco.
Nate
They didn't allow manual transmission with the Sasquatch package so I kinda feel that they need a bit of a Bronc-splaining...
