I'm positive this is overkill but wanted to get thoughts on execution, light is already purchased.
Planning to run a DD Stage Series 1" LED Pod Sport White Flood Standard White Backlight in rear cargo area using the DD GoPro mount. I was thinking I could run the backlight off of Aux 6 and wire the main light to a cigarette lighter plug. So normal "I need a bit more light back here" moments use just the backlight feature by flip of switch and the "where the F did that thing go / need to light up all the gear in middle of the night camping in the woods" moment would plug the main light in for max illumination.
Would this work? If not, I'll just skip the backlight feature and light will just be on/off w Aux 6.
