Valhalla
Valhalla
Cleveland Tn
2023 Bronco,1996 Bronco, F350, JKU, MKZ, Silverado
Everything
Exzachly
Zach
Austin, TX
23 Bronco Badlands Sasquatch
Thank you IAG. Email sent with pictures.
update. IAG responded via email with a solution that didnā€™t involve any cutting. Loosen one tiny bolt and got me enough room to muscle in the skid plate. Appreciate the customer service.
looking forward to future IAG purchases.
I'm currently having this exact same issue on my 23 Badlands! What bolt did they tell you to loosen?
NOVA Bronco
Ryan
Northern Virginia
Toyota
Having same issue. What bolt did you have to loosen? Would be great if @IAG Support would add this to the instructions.
Patkachu
Patrick
New Jersey
Audi, Bronco
Ford Bronco Coming Soon: IAG Rock Armor Skid Plates IMG_4351
Super tight fit in there. You will need a T25 bit and a small combo wrench to get in there. You donā€™t have to take it off just get like 1/8 inch space to wiggle in the skid. It wonā€™t fit at first so you will have to jam it in and wiggle it around and it will go in. I wasnā€™t able to tighten it down to the recommended torque of 11.8 ft lbs since torque wrench wonā€™t fit, so hand tightened it and jammed in some electrical tape to try to keep it secure. Iag support said itā€™s not a big deal that small bolt since there is another bolt further in and with the Iag hardware you will be fine. iAG did find the attached tool and said this could help if I really need to hand tighten it then try this: https://www.walmart.com/ip/Steelman...8?wmlspartner=wlpa&selectedSellerId=101002145
Hope that helps. Keep us posted on your success.
NOVA Bronco
Ryan
Northern Virginia
Toyota
Thanks for the info. Iā€™ll give it a go and let you know how it goes. Wish the install was as easy as the video led you to believe it was. Thatā€™s the frustrating part.
Exzachly
Zach
Austin, TX
Ford Bronco Coming Soon: IAG Rock Armor Skid Plates 1000009844
Ford Bronco Coming Soon: IAG Rock Armor Skid Plates 1000009848
Ford Bronco Coming Soon: IAG Rock Armor Skid Plates 1000009845
It took me hours to get the passenger side skid installed and it still doesn't sit right. I've been emailing back and forth with IAG support to try and figure out a solution. It looks like at this point I may end up dropping the fuel tank enough to gain access to that plate and removing it entirely.
NOVA Bronco
Ryan
Northern Virginia
Toyota
Just and FYI, the front lower control skid plates do not go on as easy as the video suggest either. Skid plate mounting holes do not line up with the factory bolts. I tried measuring it out and it looks like the mounting holes are off center by about an 1/8 of an inch. I have a Badlands with Sasquatch package and havenā€™t modified the suspension so according to the video factory hardware should work. Email sent to @IAG Support. Hoping there is a fix.
A positive note, the rear differential skid/armor installs fairly easy and as advertised. So 1 out of 3 armor kits was at least installed this weekend. Lol
NOVA Bronco
Ryan
Northern Virginia
Toyota
Finally was able to get everything installed. The passenger side was difficult but after the help from the forum and IAG customer support I figured it out. Once the skid plate was in position I used a jack to get it positioned right. Then I tightened all the bolts. I used a slim line T25 torx wrench. To get to the small hidden screw.
Ford Bronco Coming Soon: IAG Rock Armor Skid Plates IMG_9439
Ford Bronco Coming Soon: IAG Rock Armor Skid Plates IMG_9438
Ford Bronco Coming Soon: IAG Rock Armor Skid Plates IMG_9445
NOVA Bronco
Ryan
Northern Virginia
Toyota
After some man handling I got the LCA skids installed. The install is not as easy as the video leads you to believe. Just glad I was able to get them on.
Ford Bronco Coming Soon: IAG Rock Armor Skid Plates IMG_9442
jsoa
Jose
Delaware
2024 Bronco 4dr
@IAG Performance Do you guys offer installation? If so how much? looking to get everything except front and engine plates
IAG Performance
IAG Performance
JJ
Westminster, MD
www.iagperformance.com
We currently do not offer installation services but we would be happy to send some recommendations in your area if you would like to send us a DM!
jsoa
Jose
Delaware
2024 Bronco 4dr
Im close enough to drive to you, but If that isn't an option I'll probably be doing it myself, just thought who better to install them than the creators šŸ˜€
Aviatordoc
Mani
Chattanooga
2023 Wildtrack, MB SL500, Vans Aircraft RV10.
I got lucky! IAG was at Bronco super cel at Townsend and I got the entire package but the front and engine skids from them at the show price! and they installed it all for me right there!!! Fantastic folks and they did an awesome job!
IAG Performance
IAG Performance
JJ
Westminster, MD
Thanks for stopping by and thank you for your service!
moab_b2
Jason
96 FZJ80
I have been looking at your Rear Shock Trailing Arm Skid Plate and it seems like the install with the small bolts only would be a weak point. Anyone have any real world wheeling with these to verify that the install bolts are strong enough? Other sliders for the shocks use the actual factory bolt, but I dont want to have to break the 325 fl/lbs to get it on.
