My F150 will display what gear I am in on the dash, is there a setting on the Bronco that would allow you to turn this feature on?
Thanks
Thanks
Tap the manual shift button and it will display current gear, but only momentarily.
My 2021 shows current gear when I tap the top of the manual shift button. What version of the Bronco doesn't do that???It does not.
Yes that is what I was referring to was having the current gear displayed at all times.I’m sure OP clearly means have the gear displayed at all times in drive. It’s not possible.
Unfortunately no. I’ve changed everything in forscan related to gear or display and haven’t been able to get it to work.Yes that is what I was referring to was having the current gear displayed at all times.
I just thought of something, since it does show for a moment when you hit the button, then there might be a way for it to be changed using Forscan.
Thanks everyone for your replies.
As a former f150 and super duty owner I miss the display that shows which gear you are in. I noticed it was missing right away. We can still downshift though when I’m in Drive which is nice. I use it sometimes.My F150 will display what gear I am in on the dash, is there a setting on the Bronco that would allow you to turn this feature on?
Thanks
