ECU tunes for Bronco Raptor
rivasrubicon
Patric
San Antonio
Genesis G70, 2018 Corolla
I have some questions for anyone willing to answer. Im new to the word of ECU tuning. I am interested in getting one when I get my Warthog in.
1) Are there any ECU tuners beside the plug in play JB4 has to offer?
2) When watching a video, I had heard this person mention that right now it’s not accessible to anyone at the moment, does this mean that an ECU tune is out of the question at the moment?
3) What are some benefits to a Ecu tune, what are the cons?
4) What can one expect to pay when looking to get a tune?
Thank you in advance. I appreciate the future input, I’ll be responding to anyone that posts here.
LethalPerformance
Jared
South Florida
www.lethalperformance.com
Currently no. Whipple is working on a calibration as I type this. Ford Performance also has one in development. As I get more updates on both of them I'll be sure to make everyone aware.
As mentioned above Whipple and Ford Performance both have access to the PCM/Tuning software and the ability to tune/flash them. Other than those two I don't believe anyone else has support available for the Braptors yet.
Benefits to a full flash is that it has the ability to adjust shift points, shift logic, boost, spark and most of the other features that Ford uses when tuning these vehicles from the factory.
Top speed limiters can be raised, auto start/stop feature can be disabled, adjustments for tire size and gear ratios can also be changed with the device they use. These are things that a JB4 or similar device don't have the ability to do. The only con I can think of would be for those who are concerned about warranty a full flash can be detected by the dealer. In the case of Ford Performance when they release their cal t comes with a 3y/36mo warranty where the Whipple cal doesn't.
The cost of the Ford Performance device with cal will most likely fall in line with the other bronco calibrations they already offer for the 2.3L/2.7L. We offer them for $695.00 shipped. Whipple's device with cal will most likely be in the $795.00 range.
Hope that helps. If there's anything else we can do for you in the meantime please let us know.
Thanks!
Tye
Tye
San Francisco
Porsche GT3, Range Rover P525, Audi Etron Chronos
What have you seen in other broncos when comparing ford performance tune vs whipple tune? Is the whipple more aggressive? From a warranty standpoint the advantage is the ford performance tune , question is how conservative will it be compared to others
LethalPerformance
Jared
South Florida
In my opinion I feel that both Ford Performance and Whipple take a similar approach with their calibrations. Keep all of the safety features intact and be somewhat conservative on the tuning side. They want customers to have the benefits of more power, torque and the change in shift strategy while not pushing things too hard. The last thing that either of them want is to be too aggressive and see their customers have any type of failures.
Definitely a different approach then some custom tuning practices which look to squeeze every bit of power out of the vehicle and forget about longevity and safety.
Hope that helps.
rivasrubicon
rivasrubicon
Patric
San Antonio
Thanks!
Thanks, this was awesome information.
Tye
Tye
San Francisco
Hope that helps.
Thanks, given this what would be the advantage of going with a whipple tune vs ford performance tune?
HaugenRacing
Matt
Scottsdale, AZ
2022 Ford Bronco Raptor
Whipple is releasing a stage 1 package. So I would assume their flash is tuned for raptors having a whipple intercooler and intake whereas the ford will be for a stock raptor. The Whipple package will then make more power then the ford package. Hope that helps.
Raptor911
Raptor911
Broadlands, VA
There is a F150 Raptor tuner that does custom tunes via COBB. He has a huge following in the F150 Raptor community. If 10 trucks are getting a tune, I think he accounts for 7 of them.
I recently asked him if Cobb was working on the Bronco and he tells me no to the 2.3 and 2.7 BUT they are considering tuning the 3.0.
BTW .. Cobb is super slow to get into a vehicle. If Cobb does throw their hat into the ring, I am sure https://www.goosetuned.com/ will be creating an account on this forum. BTW he does own a Bronco.
swamp2
JetG
Jet
TX & FL
2018 Macan Turbo w/PP & 2016 911 Turbo Vert
If COBB comes out and tunes this is the route I will take. Had a goostuned 2018 F150 Raptor and it was a nice improvement over the stock COBB tune.
LethalPerformance
Jared
South Florida
Whipple should hopefully have some numbers here shortly. When I was out there last week Dustin and Nick were working together with their lead calibrator to build the files. Should be pretty sweet once they've got it all wrapped up.
Ford Bronco ECU tunes for Bronco Raptor 337045213_1381523212405175_7594915517572139268_n
LethalPerformance
Jared
South Florida
Tough to say at this point as we don't completely know all of the features each will offer for their calibrations. On the 2.3L/2.7L bronco stuff I do know that Whipple raises the top speed limit where Ford Performance doesn't. However until all testing and development is done for each of them I really can't compare all of the pros/cons between the two. As soon as we have more info on this stuff I'll be sure to share it with the members here.
raptorusmaximus
Horicon Wisconsin
2012 F-150 Raptor
I would pay big money for the ability to remove the hyper aggressive downshifting in sport and baja mode and make the modes more drivable.
Tye
Tye
San Francisco
Assuming Whipple will void the factory warranty while Ford Performance falls under factory warranty?
Yamapro
William
21 Bronco
I just want reliability and 500hp at the tires. I mean it’s supposed to be a performance vehicle so how about some performance!
