est1776
Il
1949 Ford F1
Thanks. I’d be interested in offset as well. Have to see if they come in 17”. They look great
They are in fact 16" America Racing Baja with a 0 offset. Below is the poke with standard flares. Since we need to sell this one, we already ordered wheels for the automatic version once it arrives. This time we went with 17s and they come with a 18 offset if I remember correctly. That'll have the Sas flares, so the poke won't be as bad, considering the 18 offset as well. We'll use the factory tires until inflation goes back down....🤣🤣
est1776
Il
1949 Ford F1
Tried zooming in. Do you know what rims these are? They are exactly what I want for my black diamond
American Racing Baja172. 16x8 0 offset.
Apologies for being off topic, just trying to answer some questions...
Ford2201
Burlington County, NJ
2008 F-150 - 2014 JKU - 1997 TJ
They are in fact 16" America Racing Baja with a 0 offset. Below is the poke with standard my flares. Since we need to sell this one, we already ordered wheels for the automatic version once it arrives. This time we went with 17s and they come with a 18 offset if I remember correctly. That'll have the Sas flares, so the poke won't be as bad, considering the 18 offset as well. We'll use the factory tires until inflation goes back down....🤣🤣
Ford Bronco Finished - White Vinyl Wrap MIC Hard Top (w/ New Closeup Pics) 20220427_190857
Thanks. Those are 35’s on 16” with non Sasquatch flares right. And you found 17’s with plus 18 offset? Mind if I ask where you found them?
est1776
Il
1949 Ford F1
My apologies, I lied.... they are a 0 offset, not sure why I was thinking 18. The rest is accurate. I found them at Extreme Customs-Tire Rep. Cool company, they threw in free lug nuts.
Ford2201
Ford Bronco Finished - White Vinyl Wrap MIC Hard Top (w/ New Closeup Pics) 20220509_184258
Thanks man. Appreciate the follow up. So you may have covered it already but………. The poke with the zero offset and standard flares is like 2” right?
peterh
ny
jeep wrangler jlu 2018
12.5 wide tires with 2 inch poke- so in theory, 285/75/17 should only be 1 inch poke!
great set up OP and est1776!
est1776
Il
1949 Ford F1
Sightings it as best as I can, it looks like 2" with standard flares. Would be less with Sasquatch flares.
Buckinghorse
Tacoma
Just picked up today. Turned out really well. Wrapped with 3m Satin White. Installer said adhered really well to the MIC top. Wrapped by InShane Designs in Lemoyne PA.
Ford Bronco Finished - White Vinyl Wrap MIC Hard Top (w/ New Closeup Pics) 20220410_151505
How's it holding up?
Fulber
Fulber
PA
15 Jetta TDI, 09 Mercedes SL63
Only a couple minor issues. Couple small areas on top of roof where the vinyl is bubbling along edges of the ridges on the roof. Can't really see unless you're up high looking closely down on roof. Also, I accidentally hit the roof on driver side with roof panel when placing back on vehicle which damaged very small area of vinyl.. Doesn't take much to scrape vinyl off so have to be very careful from now on. Used White Out to touch up which worked pretty well. But overall very happy with how its holding up.
FFF
Not a horrible price for that great and unique look. I wonder if the white roof will cut down on heat build up in the summer months while parked outside.
FDHog
Frank
NJ
2023 Lariat FX4, 22 Road Glide ST
Not a fan of white tops, but on that color, it looks friggin great.
