Ford Patents Light Weight Removable Body Door System with Built-In Tube Doors for 2021 Ford Bronco
Topnotch
NYC
Ford GT
Patent: Light weight removable body door system
https://pdfpiw.uspto.gov/.piw?Docid...&SectionNum=&idkey=NONE&Input=View+first+page
"A convertible vehicle door assembly includes a gate subassembly including an electrical panel, latch handle and is secured by hinges and a latch to a vehicle static structure. An outer door subassembly is removably secured to the gate subassembly by at least one quick connect mechanism. The outer door includes a window assembly operable by the electrical control panel."
FirstOnRaceDay
Devin
Toledo Ohio
17 Civic, 19.5 Silverado
LOVE THAT DESIGN!
tube doors are a HUGE aftermarket item for the Wrangler. Makes a lot of sense. It’s something I would definitely look into.
I love how the speakers and handles etc all stay on the tube
BAUS67
redneck
Central PA
EEFFFIINNN COOL !!!!!:thumbsup::thumbsup:
THEMANatwar
Bossier City, LA
1993 F150 Flareside, 2022 Bronco Badlands
Interesting on how it all goes together. I could see ford offering half doors too that attach to the tube frame!
chipbutty
Ontario
Nothing cool
If they are applying this type of thinking to each aspect of what makes the Wrangler a winner, we are in for one hell of a vehicle. Jeepers are always going on about tube doors. Baked in on the Bronco? Winner winner!
FirstOnRaceDay
Devin
Toledo Ohio
well the spy photos looks like it has frameless widows. So roll the window down, remove door. It’s going to be a small panel. (18” x30”) or so???
Deleted member 2346
Guest
LOVE THAT DESIGN!
IF there are speakers in the doors, I don't believe those stay with the tube door. what I think you are seeing is the four round ball-in-socket connection point between the skin and the tubes. I'm imagining the door presses into the socket and then you twist a ring to lock it in. This also explains an earlier patent for transferring power through the ball-in-socket connecting point we initially saw for the interchangeable grill patent. My assumption is there is no wire to hook up and the power window gets its power from the ball-in-socket connection. Cool.
CORRECTION: instead of "twist to lock it" its actually a button, VERY similar to the style of hoodpins on the 2020 GT500
Ford Bronco Ford Patents Light Weight Removable Body Door System with Built-In Tube Doors for 2021 Ford Bronco hoodpins_2020ShelbyGT500
FirstOnRaceDay
Devin
Toledo Ohio
Hold on......
Ford Bronco Ford Patents Light Weight Removable Body Door System with Built-In Tube Doors for 2021 Ford Bronco 43B4C369-E908-4963-A15F-2712D382B65D
Ford Bronco Ford Patents Light Weight Removable Body Door System with Built-In Tube Doors for 2021 Ford Bronco EA3AE1B5-AA19-4492-AB7F-47C9BF73C348
so the mirror is mounted on the A pillar of the frame. buuuut there is a mechanism that moves the mirror with the door as it opens???? Did i read that correctly?
FirstOnRaceDay
Devin
Toledo Ohio
reading more on that. There is an inner panel That is removable too. So door panel, tube frame, inner panel (with electric door locks) 3 pieces
