Installed Rough Country RC High Winch Mount + Light Bar
TallDude
North Seattle
2022 4dr
Got around to installing my RC high winch mount, RC 20inch single row light bar and Smittybilt 10k X20!
Really straightforward.
Couldn’t be happier for the price, fit/finish of all products.
Purchased off Amazon:
-Winch for $469 on sale (Smittybilt X2O GEN2 10K Waterproof Wireless Winch with Synthetic Rope - 98510 https://a.co/d/4iGurhg).
-Winch mount for $210 (Rough Country Winch Mount for 2021-2023 Ford Bronco - 51066 https://a.co/d/8n3oPJQ)
-Light bar for $150 (Rough Country 20" Black Series Single Row CREE LED Light Bar - 70720BL https://a.co/d/fKtwXmj)
Got all the parts ready.
Read the instructions 25 times.
I had done this once before on a Wrangler.
Then I set off.
Stock:
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar BC91BF09-5416-45CD-BA78-C0DB0096B526
Popped the plastic tow hook covers off and unbolted two inner bolts:
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar 3D744B7C-0744-4AAD-ADC2-D71C80D66804
Then assembled the fairlead on the winch plate, the winch and the light bar:
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar 668B9449-39EA-4854-AEFC-288F74612852
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar 50600484-5400-44B0-A555-084368AC91B7
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar 5285CE43-8B1D-471E-B3C5-290AD5857B1A
Then bolted it up to the bumper:
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar 768AEF13-A423-4897-86D6-82D6AD3515E4
Did some wiring (used aux 2):
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar 8049B7D8-1711-4ACA-82E2-2B9D84480EB7
Tested everything and all systems were a go:
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar 70ED2E50-D3E8-4FD3-86D8-25D2CE86F756
Went out into the world:
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar 8978EFFB-20C1-4492-A8F7-60D398F5D4DE
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar 65E54E19-F924-47F9-A810-843F33FE137B
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar 494878C7-D626-4C7E-BA18-76D8DC762330
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar 27855D56-0EAD-4645-AAB3-2F4101E95967
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar C64C21D0-4233-444A-A1C9-DCB3C829C561
Day pics:
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar 371F9841-3B55-4CE9-9C0F-E32CEB2B90AA
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar F4B010EA-48F1-48B2-82A2-0D81C4056E2E
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar 6BC1DA4A-1D44-4BF0-BCEB-38D53A2C6810
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar 27E754A2-9DD8-40D5-9258-2B14621B1983
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar A64FF482-5E8B-4B4C-8638-B1602BA96F40
TallDude
TallDude
North Seattle
2022 4dr
Added a winch cover for $20:
(Rough Country Black Universal Winch Cover Logo - RS106 https://a.co/d/8eFLyrF)
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar F07466AB-E80C-4D6E-8158-3A5F6C9D99CC
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
Thanks for the detailed pictures!
My mount recently arrived, wondering if you can help me out. One of the welds has a lot of extra slag next to the plate that will be mounted to the frame. I've attached a picture - before I start taking the bumper off and checking fitment, will I need to grind this down or does this part not need to be completely flush? If I need to do some grinding, I'd like to know before I start tearing things apart, and get stopped halfway through.
Thanks for the input.
TallDude
TallDude
North Seattle
2022 4dr
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar Screenshot_20230319-094835
Hi!
If this is the same high mount I believe there’s washers between the winch mount and the frame. It doesn’t sit flush if I recall correctly:
Ford Bronco Installed Rough Country RC High Winch Mount + Light Bar 54E31362-AA79-4DB8-AC11-33A43F3339D7
MillerAndCheeto
Robin
Calgary, AB
Hi!
Funny, I took everything out and inspected everything but didn't bother to open up the instructions yet. A good example of RTFM haha. Thanks very much.
cbrownabq
Littleton, CO
Dodge 2500 diesel
Great write up! I will have the same setup. Im going to move the control box under the hood though. Just have to wait for the bronco to ship….
MillerAndCheeto
Robin
Calgary, AB
I'm also relocating it under the hood. Going to the metal shop this weekend to get some stuff to make a little bracket. I like the mounting kits already out there, but $250 USD shipped to Canada with shipping, duties and import fees would be close to $400 CAD
GPPBronco
Detroit
2019 Ford Transit Connect; 1997 Jeep Wrangler
I realize this is an older thread, but I'm trying to resurrect some discussion - specifically related to the Rough County High Winch Mount. I'm planning to install on Saturday along with the LOD frame horn brackets. I've read/seen mixed reviews on the Rough County finish resistance to rust. No steel item is rustproof, but I'm trying to extend the life/appearance of this thing.
So, does anybody have feedback on whether they've had rust issues since installing? I'm planning to coat/wipe down parts before and after install with CRC Marine Corrosion Inhibitor, which seems to be working well on my Bronco bolts, mod bumper, etc. after two winters in the salt belt (used to be the snow belt, but now we just get salt slush for three months). Hoping to avoid spraying with paint or bedliner before the installing if I can avoid it.
Thanks!
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
So......after more than a year of having the light bar - does it significantly make a major difference? I Does the light "REACH OUT" farther than your high beams?
I same Rough Country winch mount and am considering the 20" light bar from RC......
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Thanks!
I have had my RC winch mount now for about 8 months and have ran it through snow, tons of water, a LOT of car washes......not a single show of rust. If that helps any :).
