Is this the Hardtop Prep Kit?
NTX-Bronco
Nate
Central Texas
S3, F-250
Just spotted this Bronco Wildtrack at 5 Star Ford in NRH, TX. It's a soft top, but most definitely has wiper power and washer fluid connections. I thought that it was stated previously by Ford that soft tops *would not* include these connections. Are they simply installing these connections on all Broncos now and calling this the "hardtop prep kit" for the upcoming soft top builds??
I suppose I was expecting some kit that had connectors that I (or the dealer) would have to install. While this may be a little bit of a sacrifice for cargo storage, I think this is likely a simpler option for myself as I wait for the hardtop situation to settle...
TheWoo
Manhattan, KS
2021 Gladiator Mojave
That's what's expected, but that is a Wildtrak that only has the soft top because it's a dealer mannequin. Regular soft tops won't be produced with the hard top connections until September.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
You do know that those are just the normal stowed position… they unclip from there and connect to a hardtop… or go wherever you want.
Papa Smurf
Jax, FL
‘23 Bronco WT. ‘23 Maverick. Hybrid. '23 Rav4
It has been fairly well discussed that most dealer Broncos and demo builds were built as hard tops and then sent out with a soft top instead to save the hard tops for reservations.
Roll Sound
Hollywood
2021 Wildtrack 2DR MIC OW, 2014 KTM RC8R
Is it just me or do those look like those will just break off the first time you load your Bronco with camping gear and go bouncing off road? Just plastic. Shouldn't those be recessed? Sort of a no brainer design flaw. I would just sort of cram them in the side if i could. or zip tie them down somewhere safe. What are everyone's thoughts?
peta8368
Norwalk, CA
2016 Polaris Slingshot
To summarize what others have already said, that particular vehicle is a Wildtrak, which can only be optioned as a hardtop. Therefore, it has the electronic and plumbing from a hardtop. However, it is a dealer mannequin, and they were probably having quality issue or shortages with the MIC hardtop, so a soft top was installed. Think of it as a Wildtrak order with extra soft top purchased from parts and installed.
Starting with September builds, all soft top orders will come with those connections by default. In short, every single Bronco built will have those, whether hardtop or soft top.
Peter
604Bronco
British Columbia
www.bronco6g.com
Seems fine to me. You could place it anywhere and they “could” break. However these look easier to plug in/remove vs it being recessed. Nothing’s stopping you from zip tying it somewhere else, but you might block your bottle opener ;)
MN_OuterBanks
AW
Minnesota
2015 F150 SuperCrew
Exactly what it should be. Also includes the turn signal indicator with the rear wiper controls. What exactly where you expecting ?
NTX-Bronco
Nate
Central Texas
S3, F-250
Peter
Understood. I think what I was interested to see was that it was installed already. But what others have noted is because it was originally a hardtop. An important detail I overlooked! Good to know that they will be built in after Sept!
Thanks for the info, sorry that I appear to be a little behind the curve on this one…
NTX-Bronco
Nate
Central Texas
S3, F-250
I was expected no connections because it was a soft top. As others have brought to my attention, this was originally built as a hardtop and the soft top was just tacked On after the fact. I appear to be playing catch-up on the dealer model details…
NTX-Bronco
Nate
Central Texas
S3, F-250
Understood. I’ve been a lurker for quite some time, but apparently missed quite a bit of these dealer demo details.
I am tracking now.
Thanks for the info.
NTX-Bronco
Nate
Central Texas
S3, F-250
Can you confirm if they were allowing test drives? And if so, add the info to this thread (you can edit the first post).
Sadly, I cannot. I was in a bit of a rush, stopped by for a quick look at Velocity Blue, snapped some interior pics, saw the hard top and had to ask the more-intelligent-than-I 6G community about the connections.
There was not a salesman in sight as I snapped the pics, though. Unsure if they’re really that short staffed right now, or if they’ve just had their fair share of lookie loos…
