- Matt
- Feb 27, 2022
- 9
- 125
- 123
- California
- 2021 4 door 2.3L MT
- Badlands
ordered mine from lethal last night. Can't wait.
Yes.Do we expect this to be CA legal for 2023s at some point?
They haven't released the cals for the 23 model year yet but are working on them. Once they have a EO number approved from CARB they will release them to the public. Let us know if there's anything else we can help you with in the meantime.will this version work on the MY23 models or do we need to wait for a revised version?
I've been told that's a big no-no, as in illegal, here in Texas."1st time I was coasting to a light..."
TREES!!!Hey, not to go off-topic: in this video I see that a cable is installed from the trailsight to the roof. I've grabbed a pic of it. What is this for?
It’s recommended yes. However you can run lower grade fuel but you won’t fully benefit from the calibration until you put a higher grade fuel in. The truck will adjust its timing table for the higher grade fuel and increase timing so long no knock is detected. Let’s say you’re traveling and can only get 87. Not a problem as the timing table will adjust on its own as it senses the lower grade fuel. Then when you put better grade fuel in the table will adjust and increase timing so you make more power.I'm assuming you have to run premium?
You seeing any impact to gas mileage? Not that I care too much but curious if the tune impacts it much.Quick Review and Impressions:
Device was easy to connect and setup.
After initial issues with firmware, since subsequent updates all has worked flawlessly with connecting and communciating.
Flashing Process is simple and straight forward - reading took less than a minute and subsequent flashing took about 6 mins total. All in all a 15 min process start to finish.
Changing of tire size was extremely easy - just research your tire specs in advance for their revolutions per mile and put in the prompt area when changing. Right after you are done.
Tune:
Initial impressions are great torque throughout low - mid range vs before. Shift points on automatic definitely seems better and overall smoother as i felt they were too early prior with the stock tune. Have not had time to drive on freeway, but will to review overall acceleration and passing speed which i expect to be noticeable with the power figures advertised. Overall, well worth the investment of $700 and especially over what else is on market considering a flash and warranty.
Seems to be quite the same. I also added 35" tires so I would say a slight save all being equal.You seeing any impact to gas mileage? Not that I care too much but curious if the tune impacts it much.
