- Randy
- Nov 26, 2022
- 12
- 411
- 550
- Punta Gorda, FL
- 2022 Ford Bronco, 2019 Ford F250, 2009 Ford Ranger
- Wildtrak
I need a Raptor now.
Proper response to this would be “tou-f***n-che’ “Circles have no point.
So does the Braptor have vacuum assisted brakes? Even with everything off my 2.7 Nannie’s won’t let me brake torque or spin a tire at all unless it’s wet and slick in a turn then they quickly kick in. My wife’s 2.3 you can brake torque and smoke the tires easily even with 35x12.50’s. So far the 2.3 seems better for drivability than my 2.7 the downside the 2.3 gets worse mpg.
Yes everything off holding down the button mine won’t do chit for wheel spin. The 2.3 lets you do you.When you say "everything off" do you mean even the traction control turned completely off???
at 5:14 of the video Vaughn talks about disabling the advanctrac, allowing sliding and wheel spin. Just pushing the traction control button once allows wheel spin but not once you are in a slide (referred to as yaw). By holding the traction control button for 5 seconds then you can slide and spin the tires.
I like to think of this as the "fun button". It disables ALL the nannies and allows you the driver to drive the Bronc as you see fit with no "help".
mine does... baja mode, manual shift, working the paddle shifter and some wet pavement = lots of fun dry pavement is much harder without doing a brake stand.Yes everything off holding down the button mine won’t do chit for wheel spin. The 2.3 lets you do you.
Yours is a raptor then I stated my 2.7 Nannie’s. Lol. And was wondering if the raptor had the vacuum brake assist instead of the electric brake assist that the 2.7 gets. Mine won’t let me sling for anything lol. Which is good in some ways.mine does... baja mode, manual shift, working the paddle shifter and some wet pavement = lots of fun dry pavement is much harder without doing a brake stand.
