Raptor fog lights - part #'s for install on regular Bronco?
Ladyinbluebronco
ILLINOIS
Sorry meant to say here they are from the Chicago auto show on Saturday. Rigid. They look really good.
drew707
Ford Explorer
I like that they fit so nicely and not too crowded looking. I have the modular bumper and would like to see if these will fit as nice.
They fit great but require the different end cap from the Raptor to actually bolt in. It has additional mounting points on the inside lower edge of that end piece
Pony Collector
N.Y. Land Of Taxes
2022 Bronco
NO, it’s a Bronco.
It’s getting ridiculous with “nonsasquatch“ and now “regular“ Bronco.
Just state what you have, not what you don’t have.
Example:
Anyone have part number for the Raptor fog lights? Annoying they are not available for other models.
Sorry didn't realize it was that time. Try this https://www.midol.com/.
MY post title and location were changed by admins. i assume , I didn't put it in the Special Raptor section I put it in the general Bronco section so it would't get lost.
What "other models"? Raptor and bronco are the only models according to you.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Since the raptor has factory fog lights on the mod bumper, has anyone tried to find part #’s or brand of these lights or if a wiring harness is available?
Annoying that they are not available on regular Broncos.
It's not worth it
First, while it could bolt up you won't have any wiring for it.
These kits utilize a fog light switch on the dash for 1 pair of lights, and an upfitter for the 2nd. If Ford did what they did on the Gen3 Raptors, they'll also relocate Aux 1 down to the fog pocket kit.
Second, the factory fog lights are HORRIBLE. They really don't throw out any light and the price you are going to pay to get them, is not worth it.
We've got customers ripping their Gen3 Raptor fogs off left/right in place for Baja Designs and Diode Dynamics kits. I've got a set of Gen3 raptor fogs (the Rigid ones) sitting here nobody wants.
They just don't throw much light out at all. Soooo it's honestly not worth it.
Our fog kits that we offer will bolt right up to the kit. AND we'll be providing FREE pigtails in each kit so you can use your factory fog light switch on your Bronco Raptor.
George
Kenner, LA
2022 Bronco, 2022 Ford F-150 Raptor
It's not worth it
Still, it would be nice to at least be able to buy the housing and then fit the better quality Rigid light in its place.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Why would you want to do that? We already sell fog kits for the bumper :)
George
Kenner, LA
I prefer an OEM look. I haven't seen too many of the 3 light-pod set ups that I like. Plus, if I need real off road light output, I'm going to put something above the bumper, not in those little pockets.
Tye
Tye
San Francisco
Porsche GT3, Range Rover P525, Audi Etron Chronos
Have a braptor inbound, which diodes would you recommend to replace the rigid and fit into these oem brackets?
Ryslegit
SoCal
22 Bronco Badlands Sas
Rigid now sells a triple fog kit with similar lights to those on the Raptor.
Raptor911
Raptor911
Broadlands, VA
those lights are the same ones used on the F150 raptor and they are the cheapest ones Rigid makes. BUT you can upgrade to a better LED in the same size from Rigid.
George
Kenner, LA
That was my point exactly. Just buy the housing (no lights) and use the upgraded ones from Rigid in the same size. I also have an F150 Raptor so I knew there was an upgrade in the OEM size. 👍🏻
Jhuff
J
Toyota Tacoma and DR650
We are waiting for the same thing. I do not like the idea of spending so much money on a light that mounts behind my bumper (rather than inside the pocket) and isn't easily removable for when the modular end caps come off.
If the Raptor pockets don't work or aren't removable easily, I'm looking at modifying the end cap for mounting a proper driving light with quick connects.
Jhuff
J
Oh wow those look nice. But at 1k+ it is hard to pull the trigger, and they aren't attached to the end caps, which makes them prone to damage if you pull the caps off.
Personally, I would prefer round driving lights with a halo to match the headlights. Hella sells them for about $800, but they would require some cutting & fabrication to mount them flush with (and attached only to) the end caps... Fab work which I don't have time for right now. 🙁
