- RON
- Jul 11, 2020
- 29
- 340
- 777
- Goderich Ontario
- 2018MUSTANG GT
- Outer Banks
Did Ray Charles put them on? Sorry but they should be evenly distributed if you are going to use them, these look too small to me. Owners manual says no go.
Thanks for your input. Don’t see any convincing information why you should not use them. They are consider light duty by the manufacture and made for this tire size. Lots of clearance around the wheel and they don’t touch the rims. Maybe Ford can give me a better reason.Did Ray Charles put them on? Sorry but they should be evenly distributed if you are going to use them, these look too small to me. Owners manual says no go.
USING SNOW CHAINS
Only use snow chains on rear wheels. Install snow chains in pairs. Do not use self-tensioning snow chains.
WARNING: Do not exceed 30 mph (50 km/h). Failure to follow this instruction could result in the loss of control of your vehicle, personal injury or death.
WARNING: Do not use snow chains on snow-free roads.
WARNING: Only fit snow chains to specified tires.
WARNING: If your vehicle is fitted with wheel trims, remove them before fitting snow chains.
WARNING: If you choose to install snow tires on your vehicle, they must be the same size, construction, and load range as the original tires listed on the tire placard, and they must be installed on all four wheels. Mixing tires of different size or construction on your vehicle can adversely affect your vehicle's handling and braking, and may lead to loss of vehicle control.
Only use snow chains on the following specified tire sizes:
We recommend you use steel wheels of the same size and specification if snow chains are required because chains may chip aluminum wheels.
- 255/70R16Only install chains that are 15 mm or less.
- 255/75R17Only install chains that are 15 mm or less.
Follow these guidelines when using snow tires and traction devices:
- If possible, avoid fully loading your vehicle.
- Purchase snow chains from a manufacturer that clearly labels body to tire dimension restrictions.
- When driving with snow chains do not exceed 30 mph (50 km/h) or the maximum speed recommended by the chain manufacturer, whichever is less.
- Drive cautiously. If you hear the snow chains rub or bang against the vehicle, stop and tighten them. If this does not work, remove the snow chains to prevent vehicle damage.
- Remove the snow chains when they are no longer needed. Do not use snow chains on dry roads.
- If a temporary spare wheel is mounted on your vehicle, do not use snow chains on the axle with the temporary spare wheel.
Use snow chains that fit against the sidewall of the tire to prevent the chains from touching the wheel rims or suspension, see following illustration above.
If you have any questions regarding snow chains, please contact your authorized dealer.
Truth here. I have used chains often, especially off road (not on the Bronco yet, but i always carry) they can be a life saver or the only way. Just like a hi lift jack you need to know what you are doing and take responsibility for your actions.I have been running them on my FE while on my 35" tires and after a 3" lift, on 37s. I had to notch my rear crash bars for clearance on the 37s and chains.. If I am fully loaded and I stuff a rear tire, I can hear a slight scrape up against my rear inner fender liner. With zero-offset wheels or a wheel spacer <derail discussion with various opinions on spacers here> they fit on the front well. I have posted up pictures of the clearance with 35s and 37s on this forum. If you have ever been on a sheet of ice, sliding down a steep trail towards trees or other rigs, you will appreciate the chains, even if you have never needed them on your local snowy highway! Stock offset wheels can't use chains with any real margin of safety, but I did run them that way at low speeds once to test the concept for emergency use. The first post has a setup that makes me cringe more than a little. There are lots of quality, correctly sized chains (and cables) out there.
There are some areas where they say "4WD OK with Snow Tires" (and they consider M+S a snow tire), and there are other areas (like the Sierra passes) - where they just say "Chains are Mandatory"I thought we've had threads here before that CHP doesn't care about Broncos having chains?
California does not require you to use chains. If you have 4WD with M+S tires (all Broncos do I believe) then you can pass chain control in the mountains. The regulations do say that you have to carry (not actually use) those chains in chain control areas, but few 4WD actually do.I’m going up to big bear this morning. Was wondering about chains. But saw the owners manual said to use only on the non squatch tires. Why is that? Is California the only state that requires chains?
