PAULWESTSKI
Paul
SE Virginia
00 F350 PSD, 05 Excursion PSD, VW-TDI
You could also power it though the delayed accessory circuit shown here.
I plan on running a 12 gauge fused circuit directly from the battery to a relay triggered from the delayed accessory circuit. The power feed will also have a noise suppressor after the relay.
I'll be powering both a HAM and GMRS radio from that feed. Both crammed underneath the center console.
The Midland MTX 575 will accept a cooling fan. There is a blank plate on the back of the radio for a fan. I plan on using a 5volt fan and powering it off the USB C port on the front of the radio.
As I'm modifying my MTX 575 I'll document, take photos and start a thread on the installation
Ford Bronco Super Clean GMRS Radio Install! 1699057846869
Ford Bronco Super Clean GMRS Radio Install! 1699058007315
PAULWESTSKI
Paul
SE Virginia
Sneak peak
The Motorola MTX 575 will fit under the center console console directly behind the window switches, Just ensure it's 3/4" or so above the bottom of the storage console to clear the inverter that resides underneath the center console.
Installed the 35mm fan to the GMRS
Added the speakers and microphone jacks to the divers side of the console.
Ham faceplate is mounting above the drivers sun visor.
Ford Bronco Super Clean GMRS Radio Install! 1700240187588
Ford Bronco Super Clean GMRS Radio Install! 1700239931626
Cactusjk
Scottsdale, AZ
2023 BL 2 Door, 2007 FJC
Took advantage of this forum and cleaned up the GMRS install with a RJ45 bulkhead and 3 foot Cat5 cable. Placed the bulkhead on the underside of the hvac cluster.
https://amzn.to/3xqH1nV
The wire to the right is for my auxbeam switch
Nice. I might have missed it but how hard to remove
Cactusjk
Scottsdale, AZ
Can someone point me to a thread where the M2M bracket is used to mount the 275?
Cactusjk
Scottsdale, AZ
Thanks! Was also thinking someone on here has made a video of the M2M 275 mounting.
BeerRunner
LUKE
Blythewood, SC
2023 Bronco
The Beaz
Shad
San Francisco
I noticed you did that, very clever Sir. I’ve been down the ditch light and grms rabbit hole all day after seeing this dv8 mount for drop ditches
Ford Bronco Super Clean GMRS Radio Install! IMG_0085
I like that one! Nice find! I need to redo my setup, the powder coat on the cheap bracket has failed, and now I get rust stains on my quarter panel....
BeerRunner
LUKE
Blythewood, SC
2023 Bronco
Ford Bronco Super Clean GMRS Radio Install! IMG_2186
Ford Bronco Super Clean GMRS Radio Install! IMG_2149
Ford Bronco Super Clean GMRS Radio Install! IMG_2177
Installed the 15w midland GMRS with OPs tips and used a switch that matches the badlands orange for a boom blaster 💥🐎 I got for Christmas that I put in under the hood.
Roofus
Swamp
M3/Bronco
Tell me more about boom blaster. I’m looking for something for Maryland tailgaters.
BeerRunner
LUKE
Blythewood, SC
2023 Bronco
C1 Ret
Dennis
Reno, NV
2022 Bronco
OMG, the fun I would have with the Boom Blaster!!! Gonna get one, and let the games begin!
Willwork4bronco
Will
El Paso
2007 F150
Ok
Sneak peak
Can you provide a link to where you got the fan for the MYX 575?
PAULWESTSKI
Paul
SE Virginia
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
2022 Ford Bronco Badlands Sasquatch
I usually mark out the square or rectangular hole needed. Then drill small pilot holes in each corner and a larger hole in the center (possibly more if the rectangle or square is large). Then I either dremel up to the corners or use a file to take out the remaining material. Time consuming, but the best way to get an accurate cutout with non-round openings.
Probably what I should have done. Ended up drilling just a touch too big, and the prongs don't grab entirely. I'm gathering I'll have to apply some adhesive around the edge of the plug. Got any recommendations on what works best? 🙂
