- Figmo
- Jul 17, 2022
- 34
- 675
- 1,528
- Frenchtown, MT USA
- Suzuki Samurai, Bronco 2Dr WT
- Wildtrak
I’m probably the first with this specific problem - but hoping not the first with this “type of” problem….
So I retrofitted a swaybar disconnect out of a Badlands into my Wildtrak last year. Been working fine until…
About 3 weeks ago I brought the Bronco in to the dealership for an oil change and to fix a defective seatbelt latch under warranty. As part of their inspection, they told me I had a leaking front pinion seal. They needed to order a new one and for me to come back to have that fixed under warranty. It must have been a small leak because I had not noticed any spots under my front end. But it is winter and the garage floor is pretty dirty from snow/mud. Anyway, brought it back and they put a new pinion seal in.
Just the other day, I tried to use the sway bar disconnect and found it wasn’t working. So today I put the rig up on the lift to try to figure out why. My initial theory was that the power wire that I ran down to it from one of my upfitter switches must have gotten too close to the exhaust or something and either shorted out blowing the fuse or maybe even got cut.
Fuse was fine. Testing power all the way to the unit tested fine. Basically - there’s nothing that should be preventing this thing from working near as I can tell. Unless something in the disconnect itself is broken.
That’s when it hit me. Staring up at the disconnect I realized that there would be no way to replace that front pinion seal without removing the swaybar disconnect. Obviously - the service manual wouldn’t have instructions on this step for a Wildtrak (as they did not come equipped with a disconnect)
So I’m wondering if the tech did something bad to it while servicing that front pinion seal.
I have not called the dealership yet. I was hoping to be better armed before I did because I’m pretty sure it’s gonna be a fight.
So what are our rights as customers for incidental damage to other components?
Obviously, I have no proof that the tech broke it. All I know is it was working, and now it is not. Did I literally test it the morning before bringing the Bronco in for service? No. I’d estimate it was a couple of months ago last time I used it and it worked. Did I literally test it the day I picked it up from service? Also no. Couple weeks after that is when I noticed it wasn’t working.
It’s an expensive part. And non-servicable. Meaning if it ever fails the book calls for replacing the entire unit. Pretty sure the dealer is not going to want to eat that. But I don’t feel I should have to either.
Would really love to hear from the few Ford techs I’ve seen post on this form on the past.
Am I SOL?
Am I SOL?
