Zone Lighting over 5mph?
SwampCactus
2022 4 Door Cactus Grey Badlands Sasquatch
Bump
joeb
Pennsylvania
FJ Cruiser
True. Let's Get This!!
Gluestick
Josh
Nashville
instagram.com
BMW X5, Bronco Badsquatch
This would be so helpful at dusk on trails.
joeb
Pennsylvania
FJ Cruiser
True. Would like to see this available off road.
Please
Please
Please FORD!
SwampCactus
Super useful. I have ditch lights but when these are on they pick up right behind them and is a perfect combo.
rpeary
Austin, TX
'23 Badlands SAS, 2017 Lexus RX350 F-Sport
Not even considering the @ORACLE Lighting mirror enhancement without this mandatory change. It is an absolute NEED to tie this into the factory wiring and have them operate independently above 5mph. If I did tie them into an AUX switch that would mean they both turn on at the same time and that would be detrimental in some scenarios like cruising a campground. Yes, I could tie them into two different aux switches however that does not seem like a clean solution to me considering I don't have any more AUX switches to spare, AND there is already a factory solution in place to tie in to. Seems like logic to me, however, I don't have the forscan skills to do it, unfortunately.
joeb
Pennsylvania
FJ Cruiser
Would Love To See This ! (I mean use its functionality)
Ducati1098
2022 Bronco Wildtrak, 2012 Ford Fusion
There’s no reason to keep bumping this lol if someone finds a way I’m sure they’ll post it.
Boostedblues
Kentucky
2016 Focus RS, 2011 F-250, 2004 Ranger 2016 Fusion
Having the mirror lights on at any speed would be great! In the mean time I installed some ditch lights and they work great. Much brighter and can see farther out than the mirror lights even with the wide beam pattern I got.
Chrome_Pony
Chrome
The Great Land
Seems like the easiest way was already mentioned, tap the wire for the lights, run a diode and connect it to a switch for manual operation.
Might be able to be a plug and play-ish thing if you can find the connector on Mouser, all depending on how the lights connect.
rpeary
Austin, TX
I've actually changed my mind about this since my last post on June 17th. I went ahead and bought the Oracle mirror lights and tied them to an AUX switch. So now have those and they face forward and outward and also have the factory ones which face outward only. So the coverage between the two seems perfect to me since the coverage from the Oracle's do overlap the factory ones. Yes, the factory ones still turn off above 5mph but I no longer care since they don't hold a candle to the power the Oracle's have.
Just Rob Please
Southern Illinois Hills
Blueberry F150, Jaguar XK-R Dynamic
For $440, I think I'll pass. Just not what I was looking for. I would do pods up front and a light bar for that amount of green. There *should* be a Forscan tweak .... but as others have found, appears NOT to me.
