BASE BRONCO CLUB
Base model owners can share their builds, ask questions, and discuss common issues.
DubZuc
I apologize in advance if this has been discussed before but i'm interested in swapping my base tires out for 33's (285/75 r16) and was wondering if I need, or should add a 1 inch leveling kit? Not sure what the pro's and con's would be to doing this. Also am torn between the BFG KO2's, Nitto Ridge Grapplers, or General Grabbers . I'm leaning towards BFG's but... hard decision. Any recommendations on tires?
twyoung1975
twyoung1975
There are several who have done this, and from what I've seen, there are no issues at all. I'm having the dealer install tires that size on mine before I pick it up
DubZuc
DubZuc
what tires are you going with
twyoung1975
twyoung1975
Falken Wildpeak AT3W
Reactions: DubZuc
iwantabasebronco
iwantabasebronco
I love my Falken wildpeaks. 285 75r16.
iwantabasebronco
iwantabasebronco
One note is to make sure they calibrate the Speedo. Mine reads 3-4 mph slow at highway speeds so having them look at it when I get my next oil change
RR Bronco
RR Bronco
I went with 33,s (285 70 17) and have zero issues.
DubZuc
DubZuc
You can recalibrate yourself...
DubZuc
DubZuc
So any recommendations on whether or not to level it?
Bscholl8
Bscholl8
Check out @BudgetBronco on all of these questions. I went with the Grabbers and a 2" leveling kit from Rough Country.
Reactions: DubZuc
BudgetBronco
BudgetBronco
No lift or leveling kit is required with the 285-75-16 tires. If you add one it is for looks only, and my own personal opinion it is not worth the cost, the tires look nice without it, not too 'stuffed'.
I have been very happy with the General Grabber option but all three of the ones you list are good tires and you probably can't go wrong with any of them
DubZuc
DubZuc
Thank you all for responding. Very helpful
DubZuc
DubZuc
DubZuc
BudgetBronco
BudgetBronco
Thank you! I hope it helped with your decision. I don't think you can go wrong with any of the options you were looking at.
Reactions: DubZuc
ABorges
ABorges
I just put on 33s without doing a leveling kit looks great and has plenty of clearance. Tires wise those are all good tires I would run with the one you like the best. Out of those brands they are all comparable.
