Bronco Enthusiasts of Connecticut
This group is for Connecticut Bronco and other off-road enthusiasts. Please join and we will get organized as we go down the road a bit... Want to help? Please let us know…
GreenBadlands
Bronco6G,
This is the list of parts I am thinking of getting for my build, any suggestions or feedback would be appreciated.
Thank you.
Lifts
2021-2023 Ford Bronco Fabtech 3" Lift Kit with Front Dirt Logic 2.5 Resi Coilovers and Rear Dirt Logic Resi Coilovers K2378DL
https://www.stage3motorsports.com/k2378dl-21-22-bronco-fabtech-3in-lift-kit.html
21-UP BRONCO SASQUATCH 2-3" LIFT STAGE 3 SUSPENSION SYSTEM BILLET
https://www.iconvehicledynamics.com...ch-2-3-lift-stage-3-suspension-system-billet/
21-UP BRONCO SASQUATCH 2-3" LIFT STAGE 4 SUSPENSION SYSTEM TUBULAR
https://www.iconvehicledynamics.com...h-2-3-lift-stage-4-suspension-system-tubular/
FABTECH Tie Rod Heim Kit - FTS22349
https://www.4wheelparts.com/p/fabte...Nkv59y5jBM5EhdirX8U0SGJPu410kxdRoCw9UQAvD_BwE
Tires
BFGoodrich A/T KO2 37X12.50R17
Nitto Recon Grappler 37X12.50R17
Discoverer STT PRO 37X12.50R17
If you have another suggestion for tires, I would appreciate that as well.
Wheels
Using current Sasquatch wheels are +30 offset on a 17x8.5 wheel
or
Getting aftermarket wheels:
Black Rhino Glacier 17x8 with a +35 MM Offset
Should I be using a wheel with zero offset to avoid rubbing at all or at full lock.?
Thank you.
