ORACLE Terry
Terry
New Orleans, LA
Bronco, RAM TRX, Gladiator, Wrangler JL,
Trigger is not just an accessory— it's a critical upgrade to your lighting experience. Whether you're an off-road enthusiast, a professional installer, or just someone who wants full control over their vehicle's lighting, these power distribution systems are designed to integrate perfectly with your existing setup.
Ford Bronco Trigger Controllers: New from ORACLE Lighting ORACLE_Lighting_trigger-broncohood_910x600
Complete Compatibility: Works flawlessly with all of our LED products, from powerful light bars to ultra-bright spotlights.
• Tailored for Performance: These systems have been tested to ensure they meet the highest performance standards in real-world conditions.
Ford Bronco Trigger Controllers: New from ORACLE Lighting ORACLE_Lighting_Trigger4Plus_A
Check out all of the great features at www.oraclelights.com/trigger
CliffCo
Cliff
Charlotte
2021 Iconic Silver, Big Bend Sasquatch (MIC top)
love mine!
Bruno
Bruno
Sierras
What does this do?
I need to controll my Aux lights - from my phone? While driving?
CliffCo
Cliff
Charlotte
What does this do?
For whatever reason, some of us didn't get the Aux switches, or have filled them up. This gives you a controller, that includes a wireless Aux switch bar to mount inside AND that you can also control with an app.
Bruno
Bruno
Sierras
thanks!
It would be pretty cool if the OP said that...
OracleLights
New Orleans, LA
What does this do?
The Trigger Controller is a 4 or 6 switch controller that can be used in the vehicle to control the lights and accessories you have connected to the controller module. This switch controller is wireless, meaning wires will not need to run through the firewall and can work outside the vehicleIn addition to the 4 or 6 switch controller, you can also control the same accessories using the free TRIGGER ACS PLUS App. Use the app to “TRIGGER” lights from outside the vehicle whenever you might need to activate an accessory on demand.
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
It makes Siri tell Alexa to order you a Google Nest so you can set your furnace when you turn on your fog lights.
It's not quite that advanced yet.
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
Another Trigger product!!
Introducing the first and only plug-and-play solid-state relay with Bluetooth capability! Our TRIGGER ONE device is compact and waterproof, handling up to 30 amps of current. Whether you’re working with new or existing installations, the TRIGGER ONE adds wireless control along with dimming and flashing options for your accessories. Easily control your vehicle’s lighting system using your iOS or Android mobile phone. This advanced feature helps prevent battery drain, ensuring your electronics are ready when you need them. Activate your radio system from outside the vehicle, connect it to a trailer light circuit for external lighting from your grill or campfire, or integrate it with your existing lights.
  • Integrated Bluetooth connectivity
  • Compatible with standard relays
  • Operated through the free TRIGGER ACS PLUS app
  • Enables wireless dimming and flashing control
  • Manages lights, radio systems, and more
  • Allows for flashing mode activation and brightness adjustments
Ford Bronco Trigger Controllers: New from ORACLE Lighting 4001-trigger-one_03_1596x1596-jpg
Learn More HERE:
https://www.oraclelights.com/products/trigger-one-bluetooth-solid-state-relay
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
