BA OffRoad
New York
www.broaddict.com
Bronco Badlands
When people first see the Broaddict Overhead MOLLE Panel System, most attention goes to the storage, lighting, and charging.
But there’s another part of the design that deserves a closer look:
the structure underneath it.
It Ties Into the Bronco’s Existing Upper Structure
The system isn’t simply suspended from plastic trim or attached to a few isolated roof points.
Its support structure connects through the B-pillars and the Bronco’s factory roll-bar crossmember, creating a rigid overhead assembly across the cabin.
The factory B-pillar structural brace also remains in place during installation. Only the plastic trim covers are removed.
In other words, the system is designed to work with the Bronco’s existing upper structure—not replace it.
Professional B-Pillar Support Testing Is Underway
We are currently conducting professional pull testing on the B-pillar support structure to further evaluate its structural strength and resistance to deformation.
The testing is still in progress, and the formal report has not yet been issued.
Once the testing is complete and the report is finalized, we’ll share the confirmed results with the Bronco6G community.
We’d rather wait for verified data than turn an unfinished test into a finished marketing claim.
The MOLLE panel itself is rated for 55 lbs of evenly distributed cargo. The panel load rating and the B-pillar structural pull test are two different measurements and should not be treated as the same thing.
Gravity already has enough responsibilities without creative math.
Does This Mean It’s a Roll Cage Upgrade?
No—and we want to be clear about that.
The system is not a certified roll cage, rollover-protection system, or replacement for Ford’s factory safety structure.
What it does provide is an additional rigid structure connected around the B-pillars and factory roll-bar crossmember, helping create a more stable platform for the overhead panel and rear grab handle.
That distinction matters.
We’d rather describe exactly what the system is designed to do—and wait for the testing to tell us the rest.
Why We Designed It This Way
On rough trails, anything mounted overhead needs to stay stable.
The reinforced support structure is designed to provide a solid foundation for the overhead panel, securely mounted gear, and rear grab handle while helping reduce unnecessary movement and vibration when properly installed.
The idea isn’t to turn the Bronco cabin into a competition roll cage.
It’s to make the overhead system feel like it belongs to the Bronco rather than something simply hanging from it.
For those who spend real time on uneven trails: what structural testing or information would you most want to see when the final report is available?
Get yours today: https://bit.ly/4vDtO7n
See It on Amazon:
https://bit.ly/45jLz0K
We’ll select a few active, constructive participants to receive a $30 Broaddict gift card.
Share what you’d like us to test, measure, or clarify—honest questions and feedback are welcome.
SFCMarauder
SFC
Mass
2025 Bronco
I can't seem to be able to find the installation guide on the website....I'm I blind ?
I would say, honestly... so long as you are clear about this (and, right not, it appears you are), I don't know that any testing really matters.
It's a molle panel across the roof. We'd like to know how much weight we can hang from it before it starts to bend/buckle or become a projectile hazard, and it's compatibility with various tops (there are what, 3 OEM tops now, and a slew of aftermarket ones). Apart from that... if it's not a "certified" roll cage upgrade, then what other testing would there be?
Ironcreek
Don
32.50722N x 110.92533W
2026 Raptor Avalanche
While I'm not using this particular brand of overhead molle panel I will agree that it appears that the idea of the panel seems to tighten the tow side up a bit more.
MaximuNashville
Adam
Nashville
‘25 Badlands non SAS
I love the idea of this - same question as someone else on the hardware being black? I’d also love one without the power connections - those seems super cool for anyone needing power but not sure I’d ever use them. Maybe a cover for them?
BA OffRoad
BA OffRoad
New York
www.broaddict.com
Bronco Badlands
Thanks for asking! The installation video is available here:
The digital installation manual will be uploaded shortly as well.
BA OffRoad
BA OffRoad
New York
www.broaddict.com
Bronco Badlands
Did you go to blacked out fasteners yet?
Not yet — this current batch still uses the existing silver hardware.
We’ve already passed the request for blacked-out fasteners to our procurement team for review. We agree that black hardware would give the whole system a cleaner, more integrated look inside the Bronco.
Thanks for bringing it up again — the feedback has definitely been heard.
BA OffRoad
BA OffRoad
New York
www.broaddict.com
Bronco Badlands
That’s a fair way to look at it, and we agree with the distinction.
For us, the most useful information to document is exactly what you mentioned.
The current MOLLE panel rating is 55 lbs with the load evenly distributed. We’re also conducting professional pull testing on the B-pillar support structure to better document how the mounting structure behaves under load. That testing is about strength, deformation, and mounting stability — not about presenting the system as a certified roll-cage upgrade.
For top compatibility, the current system has been designed around the applicable factory hard-top and soft-top configurations. With aftermarket tops, there are enough differences in brackets, liners, latches, and interior clearance that we don’t want to make a blanket compatibility claim without physically verifying them.
BA OffRoad
BA OffRoad
New York
www.broaddict.com
Bronco Badlands
Thanks for the thoughtful feedback.
The current hardware is natural-finish stainless steel, which is why it appears silver rather than black.
We’ve also received your suggestion and will include it in our future product development planning for review. Feedback like this is genuinely useful when we evaluate the next round of design and finish updates.
Really appreciate you taking the time to point it out — thank you for helping us make the product better.
breaddrink
Washington
Nissan's
If it's anything like the DV8 overhead storage, while it isn't intended to be a brace or anything other than storage (and so it can't be listed as those things), it absolutely does stop creaks and functions as a brace of sorts. At the end of the day, it's a braced piece of steel spanning across a part of the frame that flexes.
Many reviews have said the same.
The difference is very noticable.
Bellime
Keith
2022 Ford Bronco
Also tell engineering and sale to create a package of replacement (black finish hardware) that can be purchased when available for those who took the leap of faith. I am probably going to be one of them.
Finding this hardware in the aftermarket that doesn’t rust is a bear.
BA OffRoad
BA OffRoad
New York
www.broaddict.com
Bronco Badlands
That’s a really good suggestion — especially for owners who buy the current version and may want to switch to black hardware later.
We’ve passed the idea of offering a separate black-finish replacement hardware kit to our product and procurement teams for review. 😄
No confirmed timeline yet, but your request is officially on the list. And we really appreciate you being willing to take the leap with the current version.
Bellime
Keith
2022 Ford Bronco
If I may be so bold, how about rewarding the two us with a retro kit
Icetek
Oeiras Portugal
2012 BMW F21, 2024 Harley Road Glide, 2009 Harley Street Glide
3 of us. I just installed mine yesterday. Black hardware (and also black power button and USB trim??) would be great!!! I'll write up a short installation post next.
