- Kyle
- Sep 29, 2023
- 3
- 7
- 13
- Houston
- Website
- www.apollo-optics.com
- 2022 Wildtrak|2021GT50 |2019 F-250|2019 Raptor
- Wildtrak
21-24 Ford Bronco & 22-24 Bronco Raptor Sequential LED Projector Headlights Available at Apollo Optics for Black Friday Savings.
Available now, Black Friday pricing available 11/20.
Your 2021-2024 Ford Bronco deserves an upgrade and LED Headlights from Form Lighting are the perfect way to do it. Not only will you get a more aggressive appearance moving your daytime running light across the bottom of the lamp, but you'll also add an integrated sequential turn signal and startup sequence.
Overview. Sequential LED Headlights from Form Lighting are the perfect way to upgrade your 2021+ Bronco and Bronco Raptor. With these premium OE-grade replacements, you'll add sequential turn signals, a unique startup sequence, a diffused DRL in white or amber, and a more aggressive, blacked-out appearance.
Increased Light Output. These headlights feature four LED projectors, which provide increased output for both low beam and high beam. The top two projectors function as your low beam, while all four projectors function as your high beam, providing a sharp, strong beam pattern to illuminate the road ahead.
Startup Sequence. These headlights are packed with the latest and most modern lighting functions, including a startup or "welcome" sequence. Anytime the running lights turn on, they will illuminate in a sweeping pattern across the entire lamp, gradually increasing in intensity until it fully illuminates.
Sequential Turn Signal. These headlights feature an integrated sequential LED turn signal. Every time the turn signal is activated, amber LEDs in the horizontal bar activate in a smooth, chasing sequence. When you're finished making your turn, they automatically "switch back" to your chosen DRL.
Selectable DRL. These headlights feature a selectable DRL with a clean diffused optic, that allows you to choose between cool white or amber. Best of all, you can switch colors easily using a simple connector. There is no need to take the headlights off the vehicle!
Road Legal. Form Lighting headlights meet all SAE, DOT, FMVSS, and CMVSS standards and regulations for legal on-road use in the United States and Canada, when installed and aimed properly.
Two Year warranty. All Form Lighting products are backed by a two-year warranty.
What’s Included:
For full information, click here: FORM Lighting Bronco Headlights
If you have any additional questions please send me a direct message or email me.
• Email: [email protected]
Happy to help!
What’s Included:
- Two (2) Ford Bronco Headlights
- Two (2) Adapters
- One (1) DRL harness
- 2021-2024 Ford Bronco
- 2022-2024 Ford Bronco Raptor
Happy to help!
