- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
2021-2022 Bronco 4-Door Zone Off-Road Adventure Series 3" Lift Kit F97
2021-2022 Bronco 4-Door Zone Off-Road Adventure Series 3" Lift Kit Features:
There is no special suspension needed for Zone Off-Road lift kits. These kits build off of the existing factory suspension geometry while adding new parts to the mix. The 2021-2022 Bronco 4-Door Zone Off-Road Adventure Series 3" Lift Kit adds 2-piece strut spacers and Adventure Pro Series upper control arms. The 2-piece strut spacers are designed to maintain next level ride quality without overextending the suspension during down travel. Your suspension will be able to perform with superior ride quality no matter where you may find yourself. These strut spacers work with the Adventure Pro Series upper control arms to improve strength, wheel travel, and maintenance free-operation. You will be able to withstand any elements or terrain that are thrown your way while you are out exploring the great outdoors. Suspension upgrades are easiest and quickest ways to see improvement in your off-road vehicle's performance. The 2021-2022 4-Door Ford Bronco deserves these high-quality suspension upgrades to unlock its maximum performance. Along with all of performance enhancement, you will get 3" of front lift and 2" of rear lift for a truly dominating off-road presence.
Increased Ground Clearance for Bigger Tire and Wheel Combinations
The increased ground clearance that comes with the lift from the 2021-2022 Bronco 4-Door Zone Off-Road Adventure Series 3" Lift Kit gives you the opportunity to upgrade to bigger tire and wheel combinations. This kit allows for tire sizes from 35"-37" tires. The maximum applicable tire size is 37" x 12.5". All Zone Off-Road lift kits are designed and manufactured in the USA. This ensures that only the most quality materials and manufacturing techniques are used to craft these kits while incorporating the most innovative design concepts. Zone Off-Road has a commitment to contributing to the creation of the greatest 2021-2022 4-Door Ford Bronco off-road build possible. Not only are these lift kits highly functional, but they are very easy to install. The installation time is about 3-4 hours which is short compared to other similar lift kits. There are no special servicing or tools needed to complete it. All of the hardware is included to complete the installation including the ball joint tool. The Zone Off-Road lift kits are truly the easiest way to upgrade your suspension for improvement in off-road performance of your 2021-2022 4-Door Ford Bronco.
Fitment: 2021-2022 4-Door Ford Bronco (Sasquatch Equipped Only)
Does Not Fit Ford Bronco Sport or 2-Door Ford Bronco
For Sasquatch Package Ford Bronco Only
- Maintains vehicle ride and handling performance while improving off-road capability
- 2-piece strut spacer design maintains ride quality without overextending suspension during down travel
- Adventure Pro Series upper control arms for improved strength, travel and maintenance-free operation
- Lifts and levels the stance with clearance for oversized wheels and tires
- Designed for easy installation with ball joint tool include
- Designed and manufactured in the USA
- Includes Factory Protection Plus warranty program
- For Sasquatch Package Ford Bronco Only
- Does Not Fit Ford Bronco Sport or 2-Door Ford Bronco
